1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS and large CAN systems
To: [email protected]
Date: Wed, 16 Mar 2011 09:17:04 -0600
Hi Elliott,
On Wednesday 16 March 2011 09:19:29 Rod Nussbaumer wrote:
> We use CANbus extensively to control beam optics power supplies. These
> are controlled mostly from VME CPUs using the Tews vxWorks and more
> recently Tews Linux driver, with EPICS device support from Andrew
> Johnson's package.
The Tews driver and CAN device support are included with my drvIpac module,
but are designed for raw CANbus packets using Basic CAN only; the device
support doesn't speak any higher level protocols such as CANopen, and the
driver can only talk to the Tews Tip810 IP module.  I haven't followed
developments in CAN since I wrote it well over 10 years ago, and after reading
your description I would not recommend trying to use this for your new
development.
> > Also, is the ASYN framework the best choice if we have to develop a new
> > driver?
Something based on Asyn would probably be the best starting point for future
work, as it supports connecting to TCP, UDP and serial devices out of the box.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
Re: EPICS and large CAN systems Rolf Keitel
EPICS and large CAN systems Elliott Wolin
Re: EPICS and large CAN systems Rod Nussbaumer
Prev: Re: How to use asyn with linux-GPIB Feng Laurence
Next: RE: class library header file naming and install conventions Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS and large CAN systems Rod Nussbaumer
Next: Re: EPICS and large CAN systems Rolf Keitel
