1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS and large CAN systems
To: Elliott Wolin <[email protected]>
Cc: [email protected]
Date: Wed, 16 Mar 2011 07:19:29 -0700
Elliot:
We use CANbus extensively to control beam optics power supplies. These are controlled mostly from VME CPUs using the Tews vxWorks and more recently Tews Linux driver, with EPICS device support from Andrew Johnson's package. Most recently we have deployed CANbus from low-cost ARM CPUs running EPICS on Linux and using the open-source CANbus driver. Andrew's device support package was locally re-worked to use the open-source Linux driver (lincan). We have numerous CANbus branches with 100 or more satellite nodes (all custom built at TRIUMF). These have been used successfully for over ten years. I would be interested in having a CANbus port driver for asyn, so our custom controller nodes could be used in some more novel ways, such as exploiting their RS-232 interfaces.
TRIUMF's use of CANbus has been reported in at least one ICALEPCS.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
Elliott Wolin wrote:
To all EPICS CAN experts,
We are about to construct a 3000 channel CAN system. Please contact me
if you have any experience controlling CAN buses from EPICS.
Our current thought is to use about 8 Anagate Ethernet-to-CAN
controllers, four channels per controller, to talk to the CAN devices,
about 100 devices per CAN bus. We'd use the ASYN framework to implement
the driver that talks to the Anagate devices (they communicate via TCP/IP).
I am open to suggestions and alternative solutions. I am especially
interested in existing drivers for any type of Ethernet-based CAN
controller so that we can avoid writing a new driver.
Also, is the ASYN framework the best choice if we have to develop a new
driver?
Finally, to Marty Kraimer et al: is the Java IOC and port driver
framework ready? Might we use this instead?
Re: EPICS and large CAN systems Andrew Johnson
EPICS and large CAN systems Elliott Wolin
Prev: RE: Autosave config file Abadie Lana
Next: Re: How to use asyn with linux-GPIB Feng Laurence
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS and large CAN systems Burkhard Kolb
Next: Re: EPICS and large CAN systems Andrew Johnson
