Hi Matt & Ritesh,
On Thursday 28 April 2011 10:02:45 Matt Newville wrote:
> You didn't say which version of Epics base you're using. As far as I
> understand, subarrays require a patched version of 3.14.12, or
> 3.14.12.1. Since they're fairly new, it's entirely possible that
> client libraries made before this feature was added won't work.
Actually that's not quite right, the subArray record has been in Base for a
long time but its behavior did change slightly in 3.14.12.
The patch to 3.14.12 was necessary to be able to access arrays with more than
65535 elements, and the fix modified the IOC's CA server code only, not the CA
client code. That means Ritesh you need to make sure that the IOC you're
using was built with a version of Base that has that patch installed, or you
could just upgrade to Base R3.14.12.1 instead.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- regarding CaChannel v1.6 handling of dynamic subarrays Ritesh Sugandhi
- Re: regarding CaChannel v1.6 handling of dynamic subarrays Ritesh Sugandhi
- Re: regarding CaChannel v1.6 handling of dynamic subarrays Matt Newville
Re: Handling of a character waveform of 64k elements Ritesh Sugandhi
Re: Handling of a character waveform of 64k elements Andrew Johnson
<2011>
2025
2026
EPICS task watch dog Szalata, Zenon M.
<2011>
2025
2026
