1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Beam Synchronous Acquistion (BSA) and the Hytec Motor Postion
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 12 May 2011 11:42:54 -0700
On May 12, 2011, at 11:38 AM, Ernest L. Williams Jr. wrote:
> Mark Rivers wrote:
>>> 1ms period should be fine but I haven't
>>> checked the least time period that epicseventwait can use. Maybe Mark has better idea?
>> That depends on the OS and how it is configured.  With vxWorks it is
>> determined by the value of sysClkRateGet/Set.  The default clock period
>> on vxWorks is normally 50/60Hz, but it can easily be increased with
>> sysClkRateSet().  If you are using RTEMS I don't know what the rate of
>> the system clock is.  Also, typically if you specify a time of X for
>> epicsEventWait the actual time will be X +- epicsThreadSleepQuantum(),
>> which is the system clock period.  In other words if I ask for 16.6 ms
>> on a standard 60Hz vxWorks system I will get 0 to 16.6 ms, because the
>> next system tick can happen immediately (=0) or we may have just missed
>> one and it will happen in 16.6ms.
> Hi Mark,
> Awesome, thanks for the info.
> Till and Eric can you weigh in on this question for RTEMS?
>From <base>/src/RTEMS/base/rtems_config.c
#define CONFIGURE_MICROSECONDS_PER_TICK 20000
If you want a different value you can copy rtems_config.c to your application source directory, add it to the Makefile and make any changes you wish.  Note that this won't work for those of you dynamically loading your EPICS applications.
Eric Norum
[email protected]
Re: Beam Synchronous Acquistion (BSA) and the Hytec Motor Postion Till Straumann
Prev: Re: string "no alarm" color in edm textupdate, text monitor behavior seems to vary John William Sinclair
Next: Re: Beam Synchronous Acquistion (BSA) and the Hytec Motor Postion Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: string "no alarm" color in edm textupdate, text monitor behavior seems to vary Allison, Stephanie
