1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP (32bit)
To: "'Janet Anderson'" <[email protected]>
Cc: [email protected]
Date: Fri, 20 May 2011 16:06:39 -0500
Hi Janet,
	Actually, I was using
		SHARED_LIBRARIES=YES and STATIC_BUILD=NO.
	I saw your message answering to Kaz's question and double-checked
before I asked.  So I thought it would not be the problem.
	But after I run into sscan problem, (and asyn, too), I found an old
thread where Mark Rivers suggested using
		SHARED_LIBRARIES=NO  and STATIC_BUILD=YES
	And Tim Mooney just pointed that problem out a moment ago.
	So I went back change the options and did the Base 3.14.12.1
installation again.  Now it works!  I checked again, and sure, for 3.14.11,
I used the former option set and it worked.  Apparently it is not for
3.14.12.  I guess something is changed between the two version?
	Now I am recompiling the synApp and hope things work better there,
too.
	Thanks all for the help!
Zhan
Zhan Zhang, Ph. D.
Argonne National Laboratory
X-ray Science Division, 438-D005
9700 S. Cass Ave.
Argonne, IL 60439
Tel : 630-252-0863
Email: [email protected]
-----Original Message-----
Sent: Friday, May 20, 2011 3:30 PM
To: Zhan Zhang
Subject: Re: Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP
(32bit)
This can happen if you have  both SHARED_LIBRARIES=YES and
STATIC_BUILD=YES?
 From the CONFIG_SITE file:
#     NOTE WIN32: YES results in a DLL.  Valid settings are
#                   SHARED_LIBRARIES=YES and STATIC_BUILD=NO
#                   SHARED_LIBRARIES=NO  and STATIC_BUILD=YES
Janet
Zhan Zhang wrote:
> Hi EPICS folks,
> 	When trying to compile base 3.14.12.1 on my Cygwin installation on
> WinXp (32 bit), I got the error message about parse.c (attached at the
end).
> It is fairly similar to what Kaz described late last year in this thread--
> 	http://www.aps.anl.gov/epics/tech-talk/2010/msg02120.php
> 	However, in my case, I am not compiling for win32-x86 but for
> cygwin-x86.  There should be no '\\' problem for the paths.  I also
checked
> the file permission and my antelope.exe file is executable, both in
> Windows-native and Cygwin environment.  Similar to Kaz's experience, I had
> no problem compiling 3.14.11.  I am using Gnumake 3.8.1 coming with my
> Cygwin installation, though I am not sure hold old my cygwin is.  I kind
of
> remember that compiling 3.14.8.2 for win32-x86, I had to use 3.8.0 to deal
> with the '\\' problem.  But I just don't know how to get make-3.8.0 to
work
> with 3.14.12, because in RULES.TARGET, there is comments about 3.8.1 and
> later only.  I could not get pass that with 3.8.0.  For now, I will stick
> with 3.14.11.  But I just wonder what could cause my problem.
> 	Thanks!
> Here goes the error message (between ****)--
> $ make
> make -C ./configure install
> make[1]: Entering directory `/usr/local/base-3.14.12.1/configure'
> make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
> make[2]: Entering directory
> `/usr/local/base-3.14.12.1/configure/O.cygwin-x86'
> make[2]: Nothing to be done for `install'.
> make[2]: Leaving directory
> make[1]: Leaving directory `/usr/local/base-3.14.12.1/configure'
> make -C ./src install
> make[1]: Entering directory `/usr/local/base-3.14.12.1/src'
> make -C ./tools install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/tools'
> make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
> make[3]: Entering directory
> `/usr/local/base-3.14.12.1/src/tools/O.cygwin-x86'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/tools'
> make -C ./makeBaseApp install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/makeBaseApp'
> `/usr/local/base-3.14.12.1/src/makeBaseApp/O.cygwin-x86'
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/makeBaseApp'
> make -C ./makeBaseExt install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/makeBaseExt'
> `/usr/local/base-3.14.12.1/src/makeBaseExt/O.cygwin-x86'
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/makeBaseExt'
> make -C ./libCom install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/libCom'
> `/usr/local/base-3.14.12.1/src/libCom/O.cygwin-x86'
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/libCom'
> make -C ./toolsComm install
> make[2]: Entering directory `/usr/local/base-3.14.12.1/src/toolsComm'
> make -C ./antelope install
> `/usr/local/base-3.14.12.1/src/toolsComm/antelope'
> make -C O.cygwin-x86 -f ../Makefile TOP=../../../.. T_A=cygwin-x86 install
> make[4]: Entering directory
> `/usr/local/base-3.14.12.1/src/toolsComm/antelope/O.cygwin-x86'
> make[4]: Nothing to be done for `install'.
> make[4]: Leaving directory
> make -C ./flex install
> make[3]: Entering directory `/usr/local/base-3.14.12.1/src/toolsComm/flex'
> `/usr/local/base-3.14.12.1/src/toolsComm/flex/O.cygwin-x86'
> rm -f parse.c y.tab.c
> rm -f parse.h y.tab.h
> ../../../../bin/cygwin-x86/antelope.exe -l -d ../parse.y
> make[4]: *** [parse.c] Error 34
> make[3]: *** [install.cygwin-x86] Error 2
> make[3]: Leaving directory `/usr/local/base-3.14.12.1/src/toolsComm/flex'
> make[2]: *** [flex.install] Error 2
> make[2]: Leaving directory `/usr/local/base-3.14.12.1/src/toolsComm'
> make[1]: *** [toolsComm.install] Error 2
> make[1]: Leaving directory `/usr/local/base-3.14.12.1/src'
> make: *** [src.install] Error 2
> Zhan Zhang, Ph. D.
> 9700 S. Cass Ave.
> Argonne, IL 60439
> Tel : 630-252-0863
problem with gateway and softIoc running on same server Kevin Tsubota
Re: problem with gateway and softIoc running on same server Dirk Zimoch
RE: problem with gateway and softIoc running on same server Kevin Tsubota
Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP (32bit) Zhan Zhang
Re: Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP (32bit) Janet Anderson
Prev: Re: Problem installing EPICS Base 3.14.12.1 on Cygwin/Win XP (32bit) Janet Anderson
Next: RE: problem with gateway and softIoc running on same server Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: problem with gateway and softIoc running on same server Ralph Lange
