1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: record ring buffer flushing
To: "Hinko Kocevar" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Thu, 26 May 2011 13:02:49 -0500
Hi Hinko,
You don't say so explicitly, I assume that you are using the standard
asyn device support, and that the ring buffer you are referring to is
the one in that device support?
> Even if we manage to 'disable' the processing inside the device driver
> (in terms that no new data is written to record buffers, I/O intr
> SCANing still active), it takes quite some time to process all the
> pending requests already in the ring buffers for the corresponding
record.
How many records are involved?  By default each record only has 10
elements in its ring buffer, so each record would process at most 10
times before the ring buffer was empty.  This should be quite fast,
unless you have very many records in this state.
There is no way to tell it to flush the buffer.
However, you can decrease the size of the ring buffer, down to a single
element if you want.  The ring buffer default size is 10 values, but
this can be changed on a per-record basis by setting the dbInfo string
"FIFO" to a different value.  In your case you could set the value to
"1".  The disadvantage of this is that if there are several callbacks in
rapid succession the record will only process on the last value, it will
not process with the other values.  This may be OK in your case.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Hinko Kocevar
Sent: Thursday, May 26, 2011 4:06 AM
To: EPICS tech-talk
Subject: record ring buffer flushing
Hi all,
We are running EPICS 3.14.10 on ARM based system. Our device driver is
using asyn driver.
There are several records that are processed on I/O intr SCAN. Sometimes
the I/O rate is quite high and the system load (CPU) goes over the top,
with high (> 3.0) loadavg. When this happens IOC is sluggish to respond
to any CA requests.
record.
Only then can we successfully use the CA to set/get any other PV on the
IOC, and not worry about the delayed response and/or timeouts.
Is there a way to tell IOC or a PV record to forget the pending
events/requests in its ring buffer (eg. some kind of flush)?
This way we could be sure that the IOC will be responding in timely
fashion, when we try to access some PV, and avoid waiting for the ring
buffer to empty by itself..
Has anyone dealt with similar situation?
Any comments and suggestions are welcomed!
Thank you,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review,
retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: record ring buffer flushing Hinko Kocevar
Prev: RE: How to use multiple line text input in CSS? [SEC=UNCLASSIFIED] Chen, Xihui
Next: epicsTypes.h/inttypes.h question Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: record ring buffer flushing Hinko Kocevar
Next: Re: record ring buffer flushing Hinko Kocevar
