1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: record ring buffer flushing
To: EPICS tech-talk <[email protected]>
Date: Thu, 26 May 2011 11:05:55 +0200
Hi all,
We are running EPICS 3.14.10 on ARM based system. Our device driver is using asyn driver.
There are several records that are processed on I/O intr SCAN. Sometimes the I/O rate is quite high and the system load (CPU) goes over the top, with high (> 3.0) loadavg. When this happens IOC is sluggish to respond to any CA requests.
Even if we manage to 'disable' the processing inside the device driver (in terms that no new data is written to record buffers, I/O intr SCANing still active), it takes quite some time to process all the pending requests already in the ring buffers for the corresponding record.
Only then can we successfully use the CA to set/get any other PV on the IOC, and not worry about the delayed response and/or timeouts.
Is there a way to tell IOC or a PV record to forget the pending events/requests in its ring buffer (eg. some kind of flush)?
This way we could be sure that the IOC will be responding in timely fashion, when we try to access some PV, and avoid waiting for the ring buffer to empty by itself..
Has anyone dealt with similar situation?
Any comments and suggestions are welcomed!
Thank you,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
RE: record ring buffer flushing Mark Rivers
Prev: Re: CAJ Flow Control Bug David Brodrick
Next: RE: How to use multiple line text input in CSS? [SEC=UNCLASSIFIED] Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problems with executing caExample for 3.14.12.1 Cid, Florencio A
Next: RE: record ring buffer flushing Mark Rivers
