1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Parallel States Sequencer
To: Perrier Pierre <[email protected]>
Date: Tue, 31 May 2011 09:03:50 -0700
On 08:25 Mon 30 May     , Perrier Pierre wrote:
> Hi Ned,
> I attached a short description of my problem . I want to do a sequence algorithm which states can include other sub-states that can be executed in parallel.
> Another view of this problem is to do a non-deterministic automaton.
You may want to have a look at the Qt statemachine and epicsqt...
Qt statemachine can be used without GUI widgets (look at the pingpong example)
As far as I know, SNCSEQ is the only sequencer I know of that can be embedded in the IOC.
Emmanuel
Parallel States Sequencer Perrier Pierre
Re: Parallel States Sequencer Ned Arnold
RE: Parallel States Sequencer Perrier Pierre
Prev: Re: Xenomai Linux Andrew Johnson
Next: RE: asyn driver on Windows XP Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Parallel States Sequencer Benjamin Franksen
Next: Some epics timestamp questions 王林
