1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Some epics timestamp questions
To: <[email protected]>
Date: Fri, 27 May 2011 23:21:59 +0800
Hello All,
I have some questions about epics timestamp, my environment is EPICS-3.14.8.2 / VxWorks5.5.1 / MVME5100 and RHEL4.0 with ntpd service.
1. I use <dbpr "wanglin:calcExample",4> to show the TIME field of a record, is there any better and convenient method?
2. When I load a EPICS exampleApp and start the ntpd service on the host,
     <dbpr "wanglin:calcExample",4> will display the information like (I just show three fields here):
    TSE: 0      TSEL:CONSTANT      TIME: 0x284110812d1fe786
    While if I stop the ntpd service on the host, the information will be like:
    TSE: 0      TSEL:CONSTANT      TIME: 0x0000008c31ab9b64
    With and without ntpd service, the TIME field is very different, where the timestamp is retrieved from without ntpd,
    VxWorks time,  VxWorks internal ticks counter or elsewhere?
3. In the source file base-3.14.8.2/src/libCom/osi/os/vxWorks/iocClock.c, value piocClockPvt->clock will keep the EPICS time, routine syncNTP() will retrieve time from ntp server with the interval of iocClockSyncRate, routine epicsTimeGetCurrent() will update piocClockPvt->clock and return the current time, and routine epicsTimeGetEvent() will just return the time in piocClockPvt->clock.
What I don't understand is that, When a record is being processed, recGblGetTimeStamp() will be called, which will next call epicsTimeGetEvent() , but I think routine epicsTimeGetEvent() just return the time kept in piocClockPvt->clock and does not updated it to the current time, whereas routine epicsTimeGetCurrent() updates  piocClockPvt->clock  to the current time and return it, but who calls it? Thus I think there must be someting not correct in my mind.
So, my third question is how EPICS record get the updated current time when being processed?
Maybe my description above is not very clear.  : )
Lin Wang
Prev: Parallel States Sequencer Perrier Pierre
Next: Re: Parallel States Sequencer Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Parallel States Sequencer emmanuel_mayssat
Next: Steve Lewis Bruce Hill
