1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Mutex at the record level?
Date: Fri, 3 Jun 2011 16:33:13 -0400
Learned Friends:
I have a softIOC with a shared-resource problem.
A couple dozen 'sub' records need access to the same file.
I would like to put a mutex around the file access, but I'm stumped as to where the corresoponding variable should be defined.
It seems to me that it has to go one level "up" from the subroutine.
So my question is:  Where to park the '->lock' ?
Thanks in advance for your help.
Cheers -Mathias
Mathias Steiner
Michigan State University
Re: Mutex at the record level? Andrew Johnson
Prev: Re: cross compiler error Chen Xue
Next: RE: cross compiler error Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cross compiler error J. Lewis Muir
Next: Re: Mutex at the record level? Andrew Johnson
