1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cross compiler error
To: Chen Xue <[email protected]>
Cc: [email protected]
Date: Fri, 03 Jun 2011 10:26:29 -0500
On 6/3/11 10:05 AM, Chen Xue wrote:
> Hi, there,
> I will install the EPICS Server under vxWorks version 5.4.2 (for
> Motorola MVME 5100). I downloaded the cross-compiler file,
> cross-gcc-2.9.6.tar.gz, for linux from
> http://ics-web.sns.ornl.gov/dht/. Untar it and configured
> WIND_BASE in mkCrossGCC file. When I run ./mkCrossGCC CPU=ppc, I
> got the following error message. Could someone help me?
> Fixing /root/cross-compiler-build-dir/obj-ppc/cpp/gcc/Makefile
> to add CPU
> cd /root/cross-compiler-build-dir/obj-ppc/cpp/gcc ; mv Makefile
> Makefile.orig ;\
>     sed 's/^CROSS=/CROSS=-DCPU=PPC603 /' <Makefile.orig >Makefile
> ========= Building gas.config
> mkdir -p /root/cross-compiler-build-dir/obj-ppc/gas
> cd /root/cross-compiler-build-dir/obj-ppc/gas ;\
>     /home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure
> --with-cpu=603 --prefix=/home/chen/Cross-Compiler/host/x86-linux
> --target=powerpc-wrs-vxworks --host=i386-redhat-linux
> --with-headers=/home/chen/Cross-Compiler/target/h
> -enable-bfd-assembler
> loading cache ./config.cache
> checking for Cygwin environment... (cached) no
> checking for mingw32 environment... (cached) no
> checking host system type... i386-redhat-linux-gnu
> checking target system type... powerpc-wrs-vxworks
> checking build system type... i386-redhat-linux-gnu
> checking for gcc... (cached) gcc
> checking whether the C compiler (gcc  ) works... yes
> checking whether the C compiler (gcc  ) is a cross-compiler... no
> checking whether we are using GNU C... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for POSIXized ISC... no
> checking for a BSD compatible install... (cached)
> /usr/bin/install -c
> checking whether build environment is sane... yes
> checking whether make sets ${MAKE}... (cached) yes
> checking for working aclocal... missing
> checking for working autoconf... missing
> checking for working automake... missing
> checking for working autoheader... missing
> checking for working makeinfo... found
> checking for ld used by GCC... (cached) /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... (cached) yes
> checking for /usr/bin/ld option to reload object files...
> (cached) -r
> checking for BSD-compatible nm... (cached) /usr/bin/nm -B
> checking whether ln -s works... (cached) yes
> checking how to recognise dependant libraries... (cached) pass_all
> checking for object suffix... (cached) o
> checking for executable suffix... (cached) no
> checking for ranlib... (cached) ranlib
> checking for strip... (cached) strip
> loading cache ./config.cache within ltconfig
> checking whether -lc should be explicitly linked in... (cached) no
> checking for objdir... .libs
> checking for gcc option to produce PIC...  -fPIC -DPIC
> checking if gcc PIC flag  -fPIC -DPIC works... (cached) yes
> checking if gcc static flag -static works... (cached) yes
> checking if gcc supports -c -o file.o... yes
> checking if gcc supports -fno-rtti -fno-exceptions ... no
> checking whether the linker (/usr/bin/ld) supports shared
> libraries... yes
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking command to parse /usr/bin/nm -B output... ok
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> creating libtool
> checking whether the C compiler (gcc -g -O2 ) works... yes
> checking whether the C compiler (gcc -g -O2 ) is a
> checking for bison... no
> checking for byacc... no
> checking how to run the C preprocessor... gcc -E
> checking for flex... no
> checking for lex... no
> /home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 3437:
> flex: not found
> checking for flex... lex
> checking for yywrap in -ll... no
> checking lex output file root...
> /home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 1:
> lex: not found
> configure: error: cannot find output from lex; giving up
> make: *** [gas.config] Error 1
Hi, Chen.
It looks like perhaps you don't have bison and flex installed?
Are the binaries found when you type the following in a Bourne
shell?
$ which bison
$ which flex
On Ubuntu 10.04 LTS, there are packages named bison and flex
that would likely provide what you need.
Lewis
cross compiler error Chen Xue
Prev: RE: cross compiler error Jeff Hill
Next: Re: cross compiler error Chen Xue
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Mutex at the record level? Steiner, Mathias
