1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cross compiler error
To: "'Chen Xue'" <[email protected]>
Cc: [email protected]
Date: Fri, 3 Jun 2011 15:21:39 -0600
You need this library, probably.
http://www.gnu.org/software/gettext/
There are of course binary installs for linux.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
Sent: Friday, June 03, 2011 9:57 AM
To: Jeff Hill
Subject: Re: cross compiler error
Hi, there,
After I installed bison and flex, it worked. Now I run "./mkCrossGCC CPU=<cpu> build", it has an error message as below. Could you tell me how I could fix it?
Thank you.
Chen
make[3]: *** No rule to make target `../intl/libintl.a', needed by `ld-new'.  Stop.
make[3]: Leaving directory `/root/cross-compiler-build-dir/obj-ppc/ld'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/root/cross-compiler-build-dir/obj-ppc/ld'
make[1]: *** [all-recursive-am] Error 2
make[1]: Leaving directory `/root/cross-compiler-build-dir/obj-ppc/ld'
make[1]: Entering directory `/root/cross-compiler-build-dir/obj-ppc/ld'
Making install in po
make[2]: Entering directory `/root/cross-compiler-build-dir/obj-ppc/ld/po'
if test -r /home/chen/Cross-Compiler/host/src/gnu.ppc/ld/po/../../mkinstalldirs; then \
      /home/chen/Cross-Compiler/host/src/gnu.ppc/ld/po/../../mkinstalldirs /home/chen/Cross-Compiler/host/x86-linux/share; \
    else \
      /home/chen/Cross-Compiler/host/src/gnu.ppc/ld/mkinstalldirs /home/chen/Cross-Compiler/host/x86-linux/share; \
    fi
if test "ld" = "gettext"; then \
        /home/chen/Cross-Compiler/host/src/gnu.ppc/ld/po/../../mkinstalldirs /home/chen/Cross-Compiler/host/x86-linux/share/gettext/po; \
      else \
        /home/chen/Cross-Compiler/host/src/gnu.ppc/ld/mkinstalldirs /home/chen/Cross-Compiler/host/x86-linux/share/gettext/po; \
      fi; \
      /usr/bin/install -c -m 644 /home/chen/Cross-Compiler/host/src/gnu.ppc/ld/po/Makefile.in.in \
              /home/chen/Cross-Compiler/host/x86-linux/share/gettext/po/Makefile.in.in; \
    else \
    fi
make[2]: Leaving directory `/root/cross-compiler-build-dir/obj-ppc/ld/po'
make[2]: Entering directory `/root/cross-compiler-build-dir/obj-ppc/ld'
make[2]: *** No rule to make target `../intl/libintl.a', needed by `ld-new'.  Stop.
make[1]: *** [install-recursive] Error 1
make: *** [ld.build] Error 2
On 6/3/2011 10:24 AM, Jeff Hill wrote:
you may need to install flex and bison
Jeff
Jeffrey O. Hill           Email        [email protected]
-----Original Message-----
On Behalf Of Chen Xue
Sent: Friday, June 03, 2011 9:06 AM
To: [email protected]
Subject: cross compiler error
Hi, there,
I will install the EPICS Server under vxWorks version 5.4.2 (for
Motorola MVME 5100). I downloaded the cross-compiler file,
cross-gcc-2.9.6.tar.gz, for linux from http://ics-web.sns.ornl.gov/dht/.
Untar it and configured WIND_BASE in mkCrossGCC file. When I run
./mkCrossGCC CPU=ppc, I got the following error message. Could someone
help me?
Fixing /root/cross-compiler-build-dir/obj-ppc/cpp/gcc/Makefile to add CPU
cd /root/cross-compiler-build-dir/obj-ppc/cpp/gcc ; mv Makefile
Makefile.orig ;\
     sed 's/^CROSS=/CROSS=-DCPU=PPC603 /' <Makefile.orig >Makefile
========= Building gas.config
mkdir -p /root/cross-compiler-build-dir/obj-ppc/gas
cd /root/cross-compiler-build-dir/obj-ppc/gas ;\
     /home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure
--with-cpu=603 --prefix=/home/chen/Cross-Compiler/host/x86-linux
--target=powerpc-wrs-vxworks --host=i386-redhat-linux
--with-headers=/home/chen/Cross-Compiler/target/h -enable-bfd-assembler
loading cache ./config.cache
checking for Cygwin environment... (cached) no
checking for mingw32 environment... (cached) no
checking host system type... i386-redhat-linux-gnu
checking target system type... powerpc-wrs-vxworks
checking build system type... i386-redhat-linux-gnu
checking for gcc... (cached) gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for POSIXized ISC... no
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal... missing
checking for working autoconf... missing
checking for working automake... missing
checking for working autoheader... missing
checking for working makeinfo... found
checking for ld used by GCC... (cached) /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... (cached) yes
checking for /usr/bin/ld option to reload object files... (cached) -r
checking for BSD-compatible nm... (cached) /usr/bin/nm -B
checking whether ln -s works... (cached) yes
checking how to recognise dependant libraries... (cached) pass_all
checking for object suffix... (cached) o
checking for executable suffix... (cached) no
checking for ranlib... (cached) ranlib
checking for strip... (cached) strip
loading cache ./config.cache within ltconfig
checking whether -lc should be explicitly linked in... (cached) no
checking for objdir... .libs
checking for gcc option to produce PIC...  -fPIC -DPIC
checking if gcc PIC flag  -fPIC -DPIC works... (cached) yes
checking if gcc static flag -static works... (cached) yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -fno-rtti -fno-exceptions ... no
checking whether the linker (/usr/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking command to parse /usr/bin/nm -B output... ok
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
creating libtool
checking whether the C compiler (gcc -g -O2 ) works... yes
checking whether the C compiler (gcc -g -O2 ) is a cross-compiler... no
checking for bison... no
checking for byacc... no
checking how to run the C preprocessor... gcc -E
checking for flex... no
checking for lex... no
/home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 3437: flex:
not found
checking for flex... lex
checking for yywrap in -ll... no
checking lex output file root...
/home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 1: lex: not
found
configure: error: cannot find output from lex; giving up
make: *** [gas.config] Error 1
Thank you!
Chen
cross compiler error Chen Xue
RE: cross compiler error Jeff Hill
Re: cross compiler error Chen Xue
Prev: Mutex at the record level? Steiner, Mathias
Next: Re: Mutex at the record level? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cross compiler error Chen Xue
Next: Re: cross compiler error J. Lewis Muir
