Scott Baily wrote:
I would like to have an IOC talk to hardware that communicates using
SOAP. In theory, I could setup an appropriate protocol file for
Streamdevice and use a raw TCP connection to port 80. Has anyone done
this? Is there a better method?
Hi Scott,
I would try to do this with StreamDevice. However, StreamDevice requires
that the general form of the message is always the same. In particular
if you have multiple values in one message, the values should always
come in the same order. In SOAP, you could in principle have arbitrary
order, and arbitrary numbers of values, too. But normally a device would
not change the format randomly.
On the other hand, an XML parser for EPICS may be an interesting exercise.
Dirk
- SOAP device communication. Scott Baily
RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
Bronkhorst E-7000 series -stream device support? Burkhard Kolb
<2011>
2025
2026
Re: SOAP device communication. Peter Milne
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
