1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AreaDetector: Prosilica camera on different subnet?
To: "Bob Gunion" <[email protected]>
Cc: [email protected]
Date: Sun, 19 Jun 2011 23:07:41 -0500
Hi Bob,
I've modified the Prosilica driver to add the ability to open a camera by its IP addresss or IP DNS name, in addition to by its UniqueId.
I've tested this with cameras on the local subnet, and it works.  It should also work for cameras on other subnets, but I'll let you test that.
I've committed my changes to the SVN repository:
https://subversion.xor.aps.anl.gov/synApps/areaDetector/trunk/
I've updated the release notes and the Prosilica driver documentation, both in the repository and on our Web site here:
http://cars9.uchicago.edu/software/epics/areaDetectorReleaseNotes.html
http://cars9.uchicago.edu/software/epics/prosilicaDoc.html
Cheers,
Sent: Thu 6/16/2011 7:13 PM
To: Mark Rivers
Cc: Robert Petkus; [email protected]
Subject: Re: AreaDetector: Prosilica camera on different subnet?
Mark,
Thanks for the pointer.  I got it to work, but I had to download the latest version of the PvApi library.  Version 1.18 of PvApi is included in areaDetector 1.6, but PvCameraOpenByAddr didn't work.  When I tried version 1.24 it worked just fine.  Still testing - I haven't tried retrieving an image yet - so I'll wait until I have a little more confidence before sending you my (fairly minimal) changes.
Thanks again,
Bob
On Jun 15, 2011, at 6:09 PM, Mark Rivers wrote:
> Bob,
> If you change the configuration routine and constructor from
> int prosilicaConfig(char *portName,
>                    int uniqueId,
>                    int maxBuffers, size_t maxMemory,
>                    int priority, int stackSize)
> to
>                    const char* address,
> Then you can test "address" to see if it is an integer.  If so, it is a UniqueID, if not it is an IP address or IP name.  Then call the appropriate PvCameraOpen function.  The nice thing about making this change is that it is backwards compatible with existing startup scripts, since the iocsh can pass a unique ID as an integer or a string without requiring quotes.
> I'm on travel or I would try it myself.
> Mark
Re: AreaDetector: Prosilica camera on different subnet? Bob Gunion
Re: AreaDetector: Prosilica camera on different subnet? Robert Petkus
RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
Prev: Re: SOAP device communication. Peter Milne
Next: Re: SOAP device communication. Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AreaDetector: Prosilica camera on different subnet? Bob Gunion
Next: Re: AreaDetector: Prosilica camera on different subnet? Bob Gunion
