1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer news: latest snapshot
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Tue, 28 Jun 2011 11:53:26 +0200
On Monday, June 27, 2011, J. Lewis Muir wrote:
> On 6/27/11 4:09 PM, Benjamin Franksen wrote:
> > Yes, that was the idea. However, with the current build rules for
> > TESTPRODUCTs I see no way to communicate the distinction from the
> > Makefile to the test script. By parsing the last part of the cwd I
> > could find out the T_A, and if we adopted the above proposal, I could
> > match it with '64' inside the test script...
> I'm not understanding.  Say you could know that the fat binary
> included the i386 and x86_64 target architectures (in the make
> file or in the test script).  How does that help you?  Are you
> saying it would help because you'd be able to predict how many
> errors you should get?
No. If I knew it included x86_64 (and other, maybe 32 bit archs) then I also
knew that the SNL code should not contain 'assign' declarations to 'long' or
'unsigned long', so I knew that the generated C code should be such that the
C-preprocessor/compiler should fail compilation. This is what I want to
test.
I am fairly certain that the snc code in question is correct and will always
produce an error, so it may seem that this test is not very important. But I
may not be the last person to work on this code, and someone else might
(erroneously) think they could simplify it. (This happens to me all the
time...) A regression test makes sure such a mistake becomes obvious pretty
fast.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot J. Lewis Muir
Prev: Announcement : SiTCP for Accelerator Control Takashi OBINA
Next: RE: Record Alarm/ AsynPortDriver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer news: latest snapshot J. Lewis Muir
Next: Re: Sequencer news: latest snapshot Benjamin Franksen
