Thank you for your answer
Rime
On Tue, Jun 28, 2011 at 12:37 PM, Mark Rivers <[email protected]> wrote:
What is the SCAN state of the underlying records? It is periodic, passive, or I/O Intr. If it is not I/O Intr then your driver should implement the readInt32 method (for example) and simply return a bad status from that function when the driver detects an error. If you use the base class implementation of readInt32 then it is not possible to return an error status.
If the record is I/O Intr scanned it is not currently possible to put the record into alarm directly from the driver, but we are working on a fix for that limitation.
Sent: Tue 6/28/2011 1:58 AM
To: [email protected]
Subject: Record Alarm/ AsynPortDriver
Hello,
We are using the AsynPortDriver to implement a device support.
In some cases our requests at the lowest level to read values are either rejected or get a bad status. We would like to set these PVs to an invalid state.
Is there a way to modify the alarm status of a specific PV (ai) from this layer? Or how can we get the pointer to a specific PV in our code that uses the AsynPortDriver?
Thanks in advance
Rime
- Record Alarm/ AsynPortDriver Rime Ateia
- RE: Record Alarm/ AsynPortDriver Mark Rivers
Bug on alh (alarm handler) 1.2.26 alConfig.c file Juan.Guzman
Re: Bug on alh (alarm handler) 1.2.26 alConfig.c file Andrew Johnson
<2011>
2025
2026
Announcement : SiTCP for Accelerator Control Takashi OBINA
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
