1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Thu, 18 Aug 2011 16:41:34 -0500
On 8/18/11 3:26 PM, Tim Mooney wrote:
> Awesome!  I haven't reproduced the symptom on my x86_64 system, but
> anyway it's clear that the code needs this fix.  I'll look for other
> similar problems.
> Thanks to you both.
> Tim
Hi, Tim.
I think I've found another problem: using SSCANF to parse '-1'
with a '%d' format does not result in a value of -1.  Attached
is scalcout-corrupt2.db which demonstrates this.  After loading
it into an IOC, I did the following from a Bash shell:
  $ caget ioc23:Temperature.{VAL,SVAL}
  ioc23:Temperature.VAL          4.29497e+09
  ioc23:Temperature.SVAL         4294967295.000
The value should be -1.
Like the previous problem, it works fine with the i386
architecture class.
And if I change the '%d' to '%ld', it works fine for the x86_64
architecture class.
Lewis
# Demonstrates scalcout data corruption on 64-bit IOC (darwin-x86 with x86_64
# architecture class; EPICS Base 3.14.12.1 + Known Problems patches).  Works
# OK with i386 architecture class IOC.  Works OK with x86_64 architecture
# class if use '%ld' instead of '%d'.
# Parameters:
#   P  PV prefix (e.g. ioc23:)
record(stringin, "$(P)ReadTemperature") {
  field(VAL, "!DT -1")
  field(FLNK, "$(P)Temperature")
  field(PINI, "YES")
record(scalcout, "$(P)Temperature") {
  field(INAA, "$(P)ReadTemperature.VAL NPP MS")
  field(CALC, "SSCANF(AA,'!DT %d')")
  field(EGU, "C")
Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Bruce Hill
Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Tim Mooney
Prev: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Tim Mooney
Next: RE: Building EPICS (3-14-12-1) on Windows 7 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class Bruce Hill
