1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building EPICS (3-14-12-1) on Windows 7
To: "'Andrew Johnson'" <[email protected]>
Cc: [email protected]
Date: Thu, 18 Aug 2011 17:27:12 -0600
Ernest,
> > > 1>     Creating library com.lib and object com.exp
> > > 1>fdManager.obj : error LNK2001: unresolved external symbol
> > > ___WSAFDIsSet@8
I typed this command "mingw-get update mingw32-make" and now my mingw make
3.82 appears to be working just fine. I suspect that I am just now seeing
this issue because I merged in some R3.15 build system changes yesterday,
and R3.15 maybe uses the gnu make variable "$*" more than past releases of
the build system. The mingw32-make 3.81 also works fine here.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Thursday, August 18, 2011 4:44 PM
> To: 'Jeff Hill'; 'Andrew Johnson'
> Cc: 'Ernest L. Williams Jr.'; 'Janet Anderson'
> Closing in.
> I added "$(ECHO) $* $@" to the share lib build line below (because I can
> see that the win32 Link.shrlib uses $*) and I see that "$(ECHO) $* $@"
> produces "com Com.dll" with mingw gnu make 3.82.
> $(SHRLIBNAME) $(TESTSHRLIBNAME):$(SHRLIB_PREFIX)%$(SHRLIB_SUFFIX):
> 	@$(RM) $@
> 	$(ECHO) $* $@
> 	$(LINK.shrlib)
> ifeq ($(SHRLIB_SUFFIX),.dll)
> 	$(MT_DLL_COMMAND)
> endif
> And this is what the gnu make doc says:
>     The stem with which an implicit rule matches (see How Patterns Match).
> If the target is dir/a.foo.b and the target pattern is a.%.b then the stem
> is dir/foo. The stem is useful for constructing names of related files. In
> a static pattern rule, the stem is part of the file name that matched the
> ?%? in the target pattern.
>     In an explicit rule, there is no stem; so ?$*? cannot be determined in
> that way. Instead, if the target name ends with a recognized suffix (see
> Old-Fashioned Suffix Rules), ?$*? is set to the target name minus the
> suffix. For example, if the target name is ?foo.c?, then ?$*? is set to
> ?foo?, since ?.c? is a suffix. GNU make does this bizarre thing only for
> compatibility with other implementations of make. You should generally
> avoid using ?$*? except in implicit rules or static pattern rules.
>     If the target name in an explicit rule does not end with a recognized
> suffix, ?$*? is set to the empty string for that rule.
> Jeff
> > Sent: Thursday, August 18, 2011 4:27 PM
> > To: 'Andrew Johnson'
> > And I now see that the difference between IDE and DOS command line is in
> > fact caused by a different GNU make. The build works under GNU Make 3.81
> > but not under 3.82 (both are mingw versions)
> > C:\hill\epicsInBazaar\cvs-trunk\src\libCom>gmake -v
> > GNU Make 3.81
> > Copyright (C) 2006  Free Software Foundation, Inc.
> > This is free software; see the source for copying conditions.
> > There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> > PARTICULAR PURPOSE.
> > This program built for i686-pc-mingw32
> > C:\hill\epicsInBazaar\cvs-trunk\src\libCom>mingw32-make -v
> > GNU Make 3.82
> > Built for i386-pc-mingw32
> > Copyright (C) 2010  Free Software Foundation, Inc.
> > License GPLv3+: GNU GPL version 3 or later
> > <http://gnu.org/licenses/gpl.html>
> > This is free software: you are free to change and redistribute it.
> > There is NO WARRANTY, to the extent permitted by law.
> > Jeff
> > > Sent: Thursday, August 18, 2011 4:09 PM
> > > > which I merged into the 3.15 branch yesterday
> > > Ahh ... I see it now after updating my R3.15 mirror.
> > > BTW: I now see Earnest's link time issue also, but only when building
> in
> > > the IDE and not when building on the command line so I suspect based
> on
> > > past experience with (.c vs ..C) that we have another case sensitivity
> > > issue riding on the version of make (i.e. Com vs com causes the
> windsock
> > > library to not be included on the link line). Suspect also that my
> R3.15
> > > merge yesterday has caused this issue to show up.
> > > In the IDE:
> > > 1>  link /nologo /subsystem:windows /dll /LTCG /incremental:no
> /opt:ref
> > > /release /version:3.15 /fixed:no /debug    /implib:com.lib
> /out:com.dll
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\bucketLib.obj
> > > x86\epicsRingPointer.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\epicsRingBytes.obj
> > > trunk\src\libCom\O.win32-x86\postfix.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\calcPerform.obj
> > > trunk\src\libCom\O.win32-x86\cvtFast.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\resourceLib.obj
> > > trunk\src\libCom\O.win32-x86\epicsThrowTrace.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\dbmf.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\ellLib.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\envSubr.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\envData.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\errlog.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\errSymLib.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\errSymTbl.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\fdmgr.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\fdManager.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\freeListLib.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\gpHashLib.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\iocsh.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\registry.obj
> > x86\libComRegister.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\iocLog.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\logClient.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\macCore.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\macEnv.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\macUtil.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\aToIPAddr.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\adjustment.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\cantProceed.obj
> x86\epicsConvert.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsExit.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsStdlib.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsString.obj
> x86\truncateFile.obj
> > > x86\ipAddrToAsciiAsynchronous.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\epicsUnitTest.obj
> > > trunk\src\libCom\O.win32-x86\epicsThread.obj
> > > trunk\src\libCom\O.win32-x86\epicsMutex.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\epicsOsiMutexThreadPrivate.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsEvent.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsTime.obj
> > > x86\epicsMessageQueue.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\epicsMath.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\epicsAtomicLocked.obj
> > x86\epicsAtomicOSD.obj
> > > x86\epicsOsiStaticInstanceSketchyCmplr.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\epicsGeneralTime.obj
> x86\osiClockTime.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\osdSock.obj
> > > x86\osdSockAddrReuse.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osiSock.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\systemCallIntMech.obj
> > > x86\epicsSocketConvertErrnoToString.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdAssert.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdFindSymbol.obj
> > > trunk\src\libCom\O.win32-x86\osdInterrupt.obj
> > > trunk\src\libCom\O.win32-x86\osdPoolStatus.obj
> > > trunk\src\libCom\O.win32-x86\osdSignal.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdEnv.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\epicsReadline.obj
> > > trunk\src\libCom\O.win32-x86\epicsTempFile.obj
> > > trunk\src\libCom\O.win32-x86\epicsStdio.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdStdio.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdThread.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdMutex.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdEvent.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdTime.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdProcess.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdNetIntf.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\osdMessageQueue.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\devLibVME.obj
> x86\devLibVMEOSD.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\taskwd.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsTimer.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\timer.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\timerQueue.obj
> > > x86\timerQueueActive.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\timerQueueActiveMgr.obj
> > > x86\timerQueuePassive.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\yajl.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\yajl_alloc.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\yajl_buf.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\yajl_encode.obj
> > > trunk\src\libCom\O.win32-x86\yajl_gen.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\yajl_lex.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\yajl_parser.obj
> > > trunk\src\libCom\O.win32-x86\ConString.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\SegString.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\VariableString.obj
> > > trunk\src\libCom\O.win32-x86\ChunkedString.obj
> > > trunk\src\libCom\O.win32-x86\SegTree.obj C:\hill\epicsInBazaar\cvs-
> > > trunk\src\libCom\O.win32-x86\stringReaderHash.obj
> > > C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsGetopt.obj
> x86\setThreadName.obj
> > > x86\forceBadAllocException.obj
> > > ___WSAFDIsSet@8
> > > __imp__WSAGetLastError@0
> > > __imp__select@20
> > > 1>logClient.obj : error LNK2001: unresolved external symbol
> > __imp__send@16
> > > __imp__setsockopt@20
> > > __imp__shutdown@8
> > __imp__htons@4
> > > __imp__connect@12
> > > 1>aToIPAddr.obj : error LNK2001: unresolved external symbol
> > __imp__htonl@4
> > > 1>osdSock.obj : error LNK2001: unresolved external symbol
> > __imp__accept@12
> > > __imp__gethostbyname@4
> > > __imp__gethostbyaddr@12
> > > __imp__closesocket@4
> > __imp__socket@12
> > > __imp__WSACleanup@0
> > > __imp__WSAStartup@8
> > > 1>osiSock.obj : error LNK2001: unresolved external symbol
> __imp__ntohs@4
> __imp__ntohl@4
> > > 1>osdProcess.obj : error LNK2001: unresolved external symbol
> > > __imp__MessageBoxA@16
> > > __imp__GetUserNameA@8
> > > 1>osdNetIntf.obj : error LNK2001: unresolved external symbol
> > > __imp__WSAIoctl@36
> > > 1>com.dll : fatal error LNK1120: 21 unresolved externals
> > > Dos command line:
> > > cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0
> > > /D_CRT_SECURE_NO_DEPRECATE  /D_CRT_NONSTDC_NO_DEPRECATE
> > > /D_SCL_SECURE_NO_WARNINGS   /Ox /GL /Zi   /W3 /w44355       /MD  /TP
> > I.
> > > -I..\O.Common -I.
> > > i\compiler\msvc -I..\..\..\src\libCom\osi\compiler\default -I. -
> > > I..\..\..\src\libCom\osi\os\WIN32 -I..\..\..\src\libCom\osi\os\default
> > > I.. -I..\..\..\src\libCom\bucketLib -I..\..\..\src\libCom\ring -
> I..\..\.
> > > .\..\src\libCom\cvtFast -I..\..\..\src\libCom\cppStd -
> > > I..\..\..\src\libCom\cxxTemplates -I..\..\..\src\libCom\dbmf -
> > > I..\..\..\src\libCom\ellLib -I..\..\..\src\libCom\env -
> > > I..\..\..\src\libCom\error -I..\..\..
> > > .\..\src\libCom\freeList -I..\..\..\src\libCom\gpHash -
> > > I..\..\..\src\libCom\iocsh -I..\..\..\src\libCom\logClient -
> > > I..\..\..\src\libCom\macLib -I..\..\..\src\libCom\misc -
> > > I..\..\..\src\libCom\osi -I..\..\..\s
> > > \..\src\libCom\timer -I..\..\..\src\libCom\yajl -
> > > I..\..\..\src\libCom\BaseString -I..\..\..\include\compiler\msvc -
> > > I..\..\..\include\os\WIN32 -I..\..\..\include
> > > AllocException.cpp
> > > forceBadAllocException.cpp
> > > link /nologo /subsystem:windows /dll /map /LTCG /incremental:no
> /opt:ref
> > > /release /version:3.15 /fixed:no /debug    /implib:Com.lib
> /out:Com.dll
> > > bucketLib.obj epicsRingPointer.obj epicsRingBytes.obj
> > > obj cvtFast.obj resourceLib.obj epicsThrowTrace.obj dbmf.obj
> ellLib.obj
> > > envSubr.obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj
> fdmgr.obj
> > > fdManager.obj freeListLib.obj gpHashLib.obj iocsh.obj registry.
> > > ocLog.obj logClient.obj macCore.obj macEnv.obj macUtil.obj
> aToIPAddr.obj
> > > adjustment.obj cantProceed.obj epicsConvert.obj epicsExit.obj
> > > epicsStdlib.obj epicsString.obj truncateFile.obj
> > > epicsThread.obj epicsMutex.obj epicsOsiMutexThreadPrivate.obj
> > > epicsEvent.obj epicsTime.obj epicsMessageQueue.obj epicsMath.obj
> > > epicsAtomicLocked.obj epicsAtomicOSD.obj
> > > epicsOsiStaticInstanceSketchyCmplr.obj e
> > > lockTime.obj osdSock.obj osdSockAddrReuse.obj osiSock.obj
> > > systemCallIntMech.obj epicsSocketConvertErrnoToString.obj
> osdAssert.obj
> > > osdFindSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj
> > > osdEnv.obj
> > > empFile.obj epicsStdio.obj osdStdio.obj osdThread.obj osdMutex.obj
> > > osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj
> > osdMessageQueue.obj
> > > devLibVME.obj devLibVMEOSD.obj taskwd.obj epicsTimer.obj timer.obj
> > > ueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj yajl.obj
> > > yajl_alloc.obj yajl_buf.obj yajl_encode.obj yajl_gen.obj yajl_lex.obj
> > > yajl_parser.obj ConString.obj SegString.obj VariableString.obj Chunked
> > > tringReaderHash.obj epicsGetopt.obj setThreadName.obj
> > > forceBadAllocException.obj Com.res     ws2_32.lib advapi32.lib
> > user32.lib
> > >    Creating library Com.lib and object Com.exp
> > > Generating code
> > > Finished generating code
> > > "Installing shared library ../../../bin/win32-x86/Com.dll"
> > > "Installing library ../../../lib/win32-x86/Com.lib"
> > > gmake[1]: Leaving directory `C:/hill/epicsInBazaar/cvs-
> > > trunk/src/libCom/O.win32-x86'
> > > Jeff
> > > > From: Andrew Johnson [mailto:[email protected]]
> > > > Sent: Thursday, August 18, 2011 2:28 PM
> > > > To: Jeff Hill
> > > > Subject: Re: Building EPICS (3-14-12-1) on Windows 7
> > > > Hi Jeff,
> > > > On 2011-08-18 Jeff Hill wrote:
> > > > > Janet: should we remove this rule from R3.15 and R3.14, and if so
> > who
> > > > will
> > > > > take care of this (me or you)?
> > > > It has already gone in both branches, see commit 12247 in the 3.14
> > > branch
> > > > which I merged into the 3.15 branch yesterday (commit 12207.1.40
> > there),
> > > > and
> > > > if Ernest has applied all the Known Problems patches then this patch
> > > >     http://www.aps.anl.gov/epics/base/R3-14/12-docs/C-rule.patch
> > > > will have already removed it for him too.
> > > > - Andrew
> > > > Optimization is the process of taking something that works and
> > > > replacing it with something that almost works, but costs less.
> > > > -- Roger Needham
Re: Building EPICS (3-14-12-1) on Windows 7 Ernest L. Williams Jr.
Building EPICS (3-14-12-1) on Windows 7 Williams Jr., Ernest L.
Prev: Re: Scalcout data corruption on darwin-x86 with x86_64 arch class J. Lewis Muir
Next: Announce: sequencer release 2.1.1 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building EPICS (3-14-12-1) on Windows 7 Ernest L. Williams Jr.
Next: Re: Building EPICS (3-14-12-1) on Windows 7 Ernest L. Williams Jr.
