1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 19 Aug 2011 11:12:17 -0500
Hello,
I added EPICSlinux to the hosts file as just a local host. I am still getting the same issue. In the address list all I have in there right now is 127.0.0.1. Thanks for the help.
Cheers,
Adam Gluck | Applications Engineer | National Instruments
To:        Adam Gluck <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date:        08/19/2011 10:51 AM
Hi:
You have an <west coast>interesting</west coast> computer network setup ;-)
The root of your problem seems to be this:
com.cosylab.epics.caj.impl.ConnectionException: Failed to connect to
'/127.0.0.1:5064'.
at com.cosylab.epics.caj.impl.CAConnector.connect(CAConnector.java:138)
Caused by: java.net.UnknownHostException: EPICSlinux: EPICSlinux
at java.net.InetAddress.getLocalHost(InetAddress.java:1354)
I don't know exactly why the CAJ library wants to resolve a host name in
that context.
Do you explicitly use "EPICSlinux" in your address list?
In the past, there have been similar issues because just so that it would
later be able to present you with nice looking error messages,
the CA client library tried to resolve host names. Maybe that's related?
In any case, it might help to define EPICSlinux as a host in /etc/hosts so
that the name resolution 'works'.
-Kay
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
Prev: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
Next: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
