1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues
To: Adam Gluck <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 19 Aug 2011 12:26:04 -0400
Hi:
On 8/19/11 12:12 , "Adam Gluck" <[email protected]> wrote:
> I added EPICSlinux to the hosts file as just a local host. I am still
> getting the same issue. In the address list all I have in there right now
> is 127.0.0.1.
Well, at least we narrowed it down to a basic network issue totally outside
of CSS, so I won't be able to help you at all.
Again, no idea why the CAJ library tries to resolve 'EPICSlinux' when all
you do is use 127.0.0.1.
Maybe it's because of channel access security. The client library is trying
to send the user and host name. So it looks for what-is-my-host-name?
On the command line, do
  hostname
  host 127.0.0.1
  host EPICSlinux
all report something meaningful?
-Kay
>> The root of your problem seems to be this:
>> Caused by: java . net . UnknownHostException: EPICSlinux: EPICSlinux
>> at java . net . InetAddress . getLocalHost(InetAddress.java:1354)
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
Prev: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
Next: Re: Building EPICS (3-14-12-1) on Windows 7 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
