1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues
Date: Fri, 19 Aug 2011 13:10:31 -0500
Hi Kay,
I wanted to thank you for your help. After you pointed me to the hostname issue I was able to get it up and running. Looks like I didn't define a hostname in /etc/rc.conf. Once I did and added it to /etc/hosts I am now able to read the values back with no issues. Once again thanks for the help.
Cheers,
Adam Gluck | Applications Engineer | National Instruments
To:        Adam Gluck <[email protected]>, "[email protected]" <[email protected]>
Date:        08/19/2011 11:25 AM
Hi:
On 8/19/11 12:12 , "Adam Gluck" <[email protected]> wrote:
> I added EPICSlinux to the hosts file as just a local host. I am still
> getting the same issue. In the address list all I have in there right now
> is 127.0.0.1.
Well, at least we narrowed it down to a basic network issue totally outside
of CSS, so I won't be able to help you at all.
Again, no idea why the CAJ library tries to resolve 'EPICSlinux' when all
you do is use 127.0.0.1.
Maybe it's because of channel access security. The client library is trying
to send the user and host name. So it looks for what-is-my-host-name?
On the command line, do
 hostname
 host 127.0.0.1
 host EPICSlinux
all report something meaningful?
-Kay
>> The root of your problem seems to be this:
>> Caused by: java . net . UnknownHostException: EPICSlinux: EPICSlinux
>> at java . net . InetAddress . getLocalHost(InetAddress.java:1354)
CAJ host name quirk Re: EPICS BOY ... Kasemir, Kay
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
Prev: Re: Building EPICS (3-14-12-1) on Windows 7 Ernest L. Williams Jr.
Next: CAJ host name quirk Re: EPICS BOY ... Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
