1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asub record problems to update waveforms of string-type
To: Perrier Pierre <[email protected]>
Cc: [email protected]
Date: Fri, 23 Sep 2011 12:47:56 -0500 (CDT)
Pierre,
Probably you should look at the aSub record code, in base/src/rec.
The aSub record doesn't make a 2D array of strings as an array of
pointers to arrays of characters.  It makes a 1D array of (for
example) NOVA*MAX_STRING_SIZE characters, and sets VALA to the
address of that array.
Tim
----- Original Message -----
> From: "Perrier Pierre" <[email protected]>
> To: "Mathias Steiner" <[email protected]>, [email protected]
> Sent: Friday, September 23, 2011 11:45:49 AM
> Subject: RE: Asub record problems to update waveforms of string-type
> Thanks for your help. Indeed, now my waveform is updated at each call
> of my "asub_notify" function. Unfortunately, I've another problem,
> strings in the waveform are completely wrong (ex : "&@ñ««««") like a
> pointer error. So, I think the problem comes from the cast of
> precord->vala , what do you think about it ? I don't know what is the
> type of vala. Does anyone know ?
> Maybe someone has an example of "asub" record process function which
> updates waveforms of string-type.
> Cheers,
> Pierre Perrier
> -----Message d'origine-----
> De : Steiner, Mathias [mailto:[email protected]]
> Envoyé : vendredi 23 septembre 2011 16:47
> À : Perrier Pierre
> Objet : RE: Asub record problems to update waveforms of string-type
> Pierre,
> This may only be tangential to your problem, but I have found that
> when my aSub records update an 'analog out' variable, the value
> immediately updates everywhere.
> OTOH, when updating strings or waveform strings, they only "sort of"
> update.
> A caget will provide the updated string value, but EDM will show the
> old value. This is even true when the EDM window is killed and
> restarted -- which I don't understand at all.
> Adding FLNK, "$(P):CRExeSeq.PROC" to your aSub, though not pretty, may
> fix the immediate problem.
> Cheers -Mathias
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Perrier Pierre
> Sent: Friday, September 23, 2011 10:01 AM
> To: [email protected]
> Subject: Asub record problems to update waveforms of string-type
> Hello,
> I have some problems with the use of the “asub” record. I’m trying to
> update a waveform record with two strings. So, my EPICS database looks
> like this:
> record(waveform, "$(P):CRExeSeq") {
> field(PINI, "NO")
> field(DTYP, "Soft Channel")
> field(UDF, "0")
> field(NELM, "2")
> field(FTVL, "STRING")
> record(aSub, "$(P):_notifyCRExeSeq") {
> field(SCAN, "Event")
> field(EVNT, "4")
> field(OUTA, "$(P):CRExeSeq")
> field(SNAM, "asub_notify")
> field(PINI, "NO")
> field(FTVA, "STRING")
> field(NOVA, "2")
> field(NEVA, "2")
> The “$(P):CRExeSeq” record is updated by the “$(P):_notifyCRExeSeq”
> record when an observer class executes the “post_event(4)” function.
> The problem is that my “asub_notify” function doesn’t really update
> the string waveform. In this function, I process the update in the
> following way:
> // I get the new informations from an other class
> QStringList l_infoAnotifier =
> g_drvSequenceurMetier->getCRExecutionSequence();
> //Here, I process the update
> if(precord->nova <= l_infoAnotifier.size()){
> // I create a char**
> char** l_info =
> (char**) malloc(l_infoAnotifier.size()*sizeof(char*));
> for(int i=0;i<l_infoAnotifier.size();i++){
> l_info[i] = (char*) malloc(40*sizeof(char));
> if(l_infoAnotifier.at(i).length()<=40){
> strcpy_s(l_info[i],40,l
> l_infoAnotifier.at(i).toStdString().c_str());
> } else {
> strcpy_s(l_info[i],40,"Error too much char");
> //Copy
> try {
> char** l_stringout = (char**) precord->vala;
> memcpy_s(l_stringout,(40*precord->nova)*sizeof(char),
> l_info,(40*l_infoAnotifier.size())*sizeof(char));
> } catch (...) {
> printf("Error in the asub_notify function\n");
> //Delete
> delete[] l_info;
> In the same way, I created a process function which seems to work for
> updating waveform of double-type data. Here, I think the problem comes
> from the string type and the “memcpy” functions.
> Does anyone know how to realize asub functions for string waveforms?
> Or know why this code doesn’t work?
> Cheers,
> Pierre PERRIER
> Stagiaire - MCO LIL
> Sopra group.
> Parc Innolin
> 9 rue du Golf 33700 Merignac
> Phone : +33 (0)5 56 12 79 59
> [email protected] - www.sopragroup.com
> Ce message peut contenir des informations confidentielles dont la
> divulgation est à ce titre rigoureusement interdite en l'absence
> d'autorisation explicite de l'émetteur. Dans l'hypothèse où vous
> auriez reçu par erreur ce message, merci de le renvoyer à l’émetteur
> et de détruire toute copie.
>  Pensez à l’environnement avant d’imprimer.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
RE: Asub record problems to update waveforms of string-type Perrier Pierre
Prev: RE: Asub record problems to update waveforms of string-type Steiner, Mathias
Next: Extensions for Linux on multi-core Di Maio Franck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Asub record problems to update waveforms of string-type Perrier Pierre
