1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StreamDevice 2.5: does not find record type aai
To: [email protected]
Date: Thu, 27 Oct 2011 01:16:18 +0200
I get an error (see attached file) when I try to build StreamDevice 2.5
against EPICS base (Michael Davidsavers Debian package 3.14.11-8) and
Asyn R4-17. It complains about the record type aai which cannot be found
for the stream device support. If I comment out the lines 15 and 16 in
stream.dbd the build finishes.
Do you have any idea why aai and aao are not found? Everything worked
fine with StreamDevice 2.4.
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
make -C ./src install
make[1]: Entering directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/src'
perl /usr/lib/epics/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[2]: Entering directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/src/O.linux-x86_64'
perl ../makedbd.pl ao ai bo bi mbbo mbbi mbboDirect mbbiDirect longout longin stringout stringin waveform calcout aai aao > ../O.Common/stream.dbd
Installing created dbd file ../../../dbd/stream.dbd
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../DebugInterface.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../DummyInterface.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../AsynDriverInterface.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../EnumConverter.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../BCDConverter.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../RawConverter.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../RawFloatConverter.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../BinaryConverter.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../ChecksumConverter.cc
../ChecksumConverter.cc: In member function â??virtual bool ChecksumConverter::printPseudo(const StreamFormat&, StreamBuffer&)â??:
../ChecksumConverter.cc:550:63: warning: suggest parentheses around arithmetic in operand of â??^â?? [-Wparentheses]
../ChecksumConverter.cc: In member function â??virtual int ChecksumConverter::scanPseudo(const StreamFormat&, StreamBuffer&, long int&)â??:
../ChecksumConverter.cc:611:63: warning: suggest parentheses around arithmetic in operand of â??^â?? [-Wparentheses]
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../MantissaExponentConverter.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../TimestampConverter.cc
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devaoStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devaiStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devboStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devbiStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devmbboStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devmbbiStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devmbboDirectStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devmbbiDirectStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devlongoutStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devlonginStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devstringoutStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devstringinStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devwaveformStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devcalcoutStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devaaiStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../devaaoStream.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamVersion.c
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamBuffer.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamError.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamProtocol.cc
../StreamProtocol.cc: In constructor â??StreamProtocolParser::Protocol::Protocol(const StreamProtocolParser::Protocol&, StreamBuffer&, int)â??:
../StreamProtocol.cc:751:22: warning: array subscript is above array bounds [-Warray-bounds]
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamFormatConverter.cc
perl ../makeref.pl Interface Debug Dummy AsynDriver > streamReferences
perl ../makeref.pl Converter Enum BCD Raw RawFloat Binary Checksum MantissaExponent Timestamp >> streamReferences
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamCore.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamBusInterface.cc
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include  -I../../../../../../support/asyn/trunk/include        ../StreamEpics.cc
/usr/bin/ar -rc   libstream.a         DebugInterface.o DummyInterface.o AsynDriverInterface.o EnumConverter.o BCDConverter.o RawConverter.o RawFloatConverter.o BinaryConverter.o ChecksumConverter.o MantissaExponentConverter.o TimestampConverter.o devaoStream.o devaiStream.o devboStream.o devbiStream.o devmbboStream.o devmbbiStream.o devmbboDirectStream.o devmbbiDirectStream.o devlongoutStream.o devlonginStream.o devstringoutStream.o devstringinStream.o devwaveformStream.o devcalcoutStream.o devaaiStream.o devaaoStream.o StreamVersion.o StreamBuffer.o StreamError.o StreamProtocol.o StreamFormatConverter.o StreamCore.o StreamBusInterface.o StreamEpics.o
/usr/bin/ranlib libstream.a
/usr/bin/g++ -o libstream.so -shared -fPIC -Wl,-soname,libstream.so -Wl,-hlibstream.so -L/home/marko/acs/frameworks/epics/support/asyn/trunk/lib/linux-x86_64 -L/usr/lib/epics/lib/linux-x86_64 -Wl,-rpath,/home/marko/acs/frameworks/epics/support/asyn/trunk/lib/linux-x86_64 -Wl,-rpath,/usr/lib/epics/lib/linux-x86_64       -m64                DebugInterface.o DummyInterface.o AsynDriverInterface.o EnumConverter.o BCDConverter.o RawConverter.o RawFloatConverter.o BinaryConverter.o ChecksumConverter.o MantissaExponentConverter.o TimestampConverter.o devaoStream.o devaiStream.o devboStream.o devbiStream.o devmbboStream.o devmbbiStream.o devmbboDirectStream.o devmbbiDirectStream.o devlongoutStream.o devlonginStream.o devstringoutStream.o devstringinStream.o devwaveformStream.o devcalcoutStream.o devaaiStream.o devaaoStream.o StreamVersion.o StreamBuffer.o StreamError.o StreamProtocol.o StreamFormatConverter.o StreamCore.o StreamBusInterface.o StreamEpics.o   -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread   -lreadline -lncurses -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libstream.so
Installing library ../../../lib/linux-x86_64/libstream.a
/usr/bin/ranlib ../../../lib/linux-x86_64/libstream.a
make[2]: Leaving directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/src/O.linux-x86_64'
make[1]: Leaving directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/src'
make -C ./streamApp install
make[1]: Entering directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/streamApp'
mkdir O.Common
make[2]: Entering directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/streamApp/O.linux-x86_64'
perl /usr/lib/epics/bin/linux-x86_64/makeIncludeDbd.pl base.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd drvVxi11.dbd stream.dbd ../O.Common/streamAppInclude.dbd
Expanding dbd
/usr/lib/epics/bin/linux-x86_64/dbExpand  -I . -I .. -I ../../../dbd -I/usr/lib/epics/dbd -I../../../../../../support/asyn/trunk/dbd -o ../O.Common/streamApp.dbd ../O.Common/streamAppInclude.dbd
Record type "aai" not found for device "stream"
Error at or before ")" in path "../../../dbd"  file "stream.dbd" line 15
 in file "../O.Common/streamAppInclude.dbd" line 5
Record type "aao" not found for device "stream"
Error at or before ")" in path "../../../dbd"  file "stream.dbd" line 16
 in file "../O.Common/streamAppInclude.dbd"dbExpand: Input errors, no output generated
make[2]: *** [../O.Common/streamApp.dbd] Error 1
make[2]: Leaving directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/streamApp/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/marko/acs/frameworks/epics/iocapps/serial2ethernet/trunk/StreamDevice-2-5/streamApp'
make: *** [streamApp.install] Error 2
device(ao,INST_IO,devaoStream,"stream")
device(ai,INST_IO,devaiStream,"stream")
device(bo,INST_IO,devboStream,"stream")
device(bi,INST_IO,devbiStream,"stream")
device(mbbo,INST_IO,devmbboStream,"stream")
device(mbbi,INST_IO,devmbbiStream,"stream")
device(mbboDirect,INST_IO,devmbboDirectStream,"stream")
device(mbbiDirect,INST_IO,devmbbiDirectStream,"stream")
device(longout,INST_IO,devlongoutStream,"stream")
device(longin,INST_IO,devlonginStream,"stream")
device(stringout,INST_IO,devstringoutStream,"stream")
device(stringin,INST_IO,devstringinStream,"stream")
device(waveform,INST_IO,devwaveformStream,"stream")
device(calcout,INST_IO,devcalcoutStream,"stream")
device(aai,INST_IO,devaaiStream,"stream")
device(aao,INST_IO,devaaoStream,"stream")
driver(stream)
variable(streamDebug, int)
registrar(streamRegistrar)
Re: StreamDevice 2.5: does not find record type aai Tim Mooney
RE: StreamDevice 2.5: does not find record type aai Davidsaver, Michael
Prev: Master index couldn't point to the data files Mi Qingru
Next: Re: StreamDevice 2.5: does not find record type aai Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
