1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice 2.5: does not find record type aai
To: Martin Konrad <[email protected]>
Cc: [email protected]
Date: Wed, 26 Oct 2011 20:08:28 -0500 (CDT)
Martin,
That rings a bell.  If I recall correctly, those records were commented out of base/src/rec/Makefile in some version of base that I was using at some point.  Or maybe the records were built, but they weren't included in base/dbd/base.dbd.  Something like that.  The easiest thing is probably to edit base/src/rec/Makefile and rebuild base.
Tim
----- Original Message -----
To: [email protected]
Sent: Wednesday, October 26, 2011 6:16:18 PM
Subject: StreamDevice 2.5: does not find record type aai
I get an error (see attached file) when I try to build StreamDevice 2.5
against EPICS base (Michael Davidsavers Debian package 3.14.11-8) and
Asyn R4-17. It complains about the record type aai which cannot be found
for the stream device support. If I comment out the lines 15 and 16 in
stream.dbd the build finishes.
Do you have any idea why aai and aao are not found? Everything worked
fine with StreamDevice 2.4.
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
StreamDevice 2.5: does not find record type aai Martin Konrad
Prev: StreamDevice 2.5: does not find record type aai Martin Konrad
Next: Delta Tau UK - Tech Talk - precision motion for Synchrotron Rings Delta Tau UK
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: StreamDevice 2.5: does not find record type aai Davidsaver, Michael
