1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StreamDevice 2.5: does not find record type aai
To: "Martin Konrad" <[email protected]>, <[email protected]>
Date: Thu, 27 Oct 2011 09:41:21 -0400
Hi Martin,
In streamApp/Makefile
# In 3.14.12 aaiRecord.dbd and aaoRecord.dbd are part of base.dbd
# In earlier versions, these records are buggy and not included by default
#streamApp_DBD += aaiRecord.dbd aaoRecord.dbd
Uncomment the third line.
Michael
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Martin Konrad
> Sent: Wednesday, October 26, 2011 7:16 PM
> To: [email protected]
> Subject: StreamDevice 2.5: does not find record type aai
> Hi,
> I get an error (see attached file) when I try to build StreamDevice 2.5
> against EPICS base (Michael Davidsavers Debian package 3.14.11-8) and
> Asyn R4-17. It complains about the record type aai which cannot be
> found for the stream device support. If I comment out the lines 15 and
> 16 in stream.dbd the build finishes.
> Do you have any idea why aai and aao are not found? Everything worked
> fine with StreamDevice 2.4.
> Cheers
> Martin
> Dipl. Phys. Martin Konrad
> Technische Universität Darmstadt
> Institut für Kernphysik
> Schlossgartenstr. 9
> 64289 Darmstadt
> Tel.: +49-6151-16-5121
> Fax: +49-6151-16-4321
StreamDevice 2.5: does not find record type aai Martin Konrad
Prev: Delta Tau UK - Tech Talk - precision motion for Synchrotron Rings Delta Tau UK
Next: EtherIP device support for stringout record William Lu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice 2.5: does not find record type aai Tim Mooney
Next: Delta Tau UK - Tech Talk - precision motion for Synchrotron Rings Delta Tau UK
