1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: vxWorks NTP Sync
To: <[email protected]>
Date: Mon, 21 Nov 2011 12:16:00 +0000
When using the EPICS_TS_NTP_INET environment variable on a vxWorks 3.14.10 IOC, issuing the command NTPTime_Report(1) I see the NTP server I am synchronised to as my boot server rather than the one specified in EPICS_TS_NTP_INET.
If I then issue an osdNTPInit command, I see NTPTime_Report(1) show correct NTP synchronisation with my desired NTP server from EPICS_TS_NTP_INET.
So, who is responsible for issuing osdNTPInit?  Is it called automatically during iocInit somehow, or should I be calling it explicitly in my startup file?
Graham
Scanned by iCritical.
Re: vxWorks NTP Sync Andrew Johnson
Prev: Re: EPICS stackoverflow site Pete R. Jemian
Next: undefined symbol when loading EPICS IOC on vxWorks 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: documentation for stringout fields Kevin Peterson
Next: Re: vxWorks NTP Sync Andrew Johnson
