1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxWorks NTP Sync
To: [email protected]
Date: Mon, 21 Nov 2011 11:43:41 -0600
Hi Graham,
On 2011-11-21 [email protected] wrote:
> When using the EPICS_TS_NTP_INET environment variable on a vxWorks 3.14.10
> IOC, issuing the command NTPTime_Report(1) I see the NTP server I am
> synchronised to as my boot server rather than the one specified in
> EPICS_TS_NTP_INET.
> If I then issue an osdNTPInit command, I see NTPTime_Report(1) show correct
> NTP synchronisation with my desired NTP server from EPICS_TS_NTP_INET.
> So, who is responsible for issuing osdNTPInit?  Is it called automatically
> during iocInit somehow, or should I be calling it explicitly in my startup
> file?
It is called automatically from a C++ static constructor, so it looks at the
value of the EPICS_TS_NTP_INET variable at the time when the vxWorks ld
command gets run.  If you want it to tell it to use a non-default NTP server
you will need to have set the environment variable before your .munch file
gets loaded.  We can't wait until iocInit() since other routines such as
driver or device support initialization, dbLoadDatabase() or dbLoadRecords()
need to know the time before then.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
vxWorks NTP Sync graham.cox
Prev: undefined symbol when loading EPICS IOC on vxWorks 王林
Next: Software controls position available at W.M. Keck Observatory Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: vxWorks NTP Sync graham.cox
Next: undefined symbol when loading EPICS IOC on vxWorks 王林
