1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: undefined symbol when loading EPICS IOC on vxWorks
To: <[email protected]>
Date: Mon, 21 Nov 2011 20:41:40 +0800
Hello All,
When I load EPICS IOC on vxWorks, the following error informatioin appears,
-> </home/wanglin/vx6_6App/iocBoot/iocexmaple/st.cmd
## Example vxWorks startup file
## The following is needed if your board support package doesn't at boot time
## automatically cd to the directory containing its startup script
#cd "/home/wanglin/vx6_6App/iocBoot/iocexmaple"
#< cdCommands
#< ../nfsCommands
#cd topbin
cd "/home/wanglin/vx6_6App"
value = 0 = 0x0
ld < bin/vxWorks-ppc604_long/exmaple.munch
Warning: module 0x1fffb390 holds reference to undefined symbol __gxx_personality_v0.
Warning: module 0x1fffb390 holds reference to undefined symbol _Unwind_Resume.
Warning: module 0x1fffb390 holds reference to undefined symbol __cxa_pure_virtual.
Warning: module 0x1fffb390 holds reference to undefined symbol _ZTIv.
ld(): error loading file (errno = 0xe0005).
value = 0 = 0x0
The EPICS version is 3.14.11, the vxWork version is 6.6 with a patch cum.vxw6-4.1.2-ppc.2010aug12.zip, the host is RHEL4.8, the target is mvme5100. And when I use "grep   _Unwind_Resume   vxWorks_6.6_1   vxWorks_6.6_1.sym" command, nothing matches. I have added the required and optional components when building vxworks image following this link http://www.aps.anl.gov/epics/base/vxWorks6.php , does it means that I need to add other components? But which components? How can I find them?
Lin Wang
Re: undefined symbol when loading EPICS IOC on vxWorks Andrew Johnson
Prev: vxWorks NTP Sync graham.cox
Next: Re: vxWorks NTP Sync Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vxWorks NTP Sync Andrew Johnson
Next: Re: undefined symbol when loading EPICS IOC on vxWorks Andrew Johnson
