1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Writing long strings PV in BOY
To: John Hammonds <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 23 Nov 2011 15:08:22 -0500
Hi John,
Thank you for the answer. I reviewed your code. I didn't see any problem. If you have tested that code and didn't find any problem, please submit your code to source forge.
Hi Juan,
In JavaScript, you cannot create Integer[], but you can create it in Python Script. Here is the python code that should work for you:
from org.csstudio.opibuilder.scriptUtil import PVUtil
from jarray import zeros
from java.lang import Integer
strArray = zeros(20,Integer);
for i in range(20):
  strArray[i] = 0;
pv = widget.getPV();
strText = "this is a test";
for i in range(len(strText)):
  strArray[i] = ord(strText[i]);
pv.setValue(strArray);
Xihui
> -----Original Message-----
> From: John Hammonds [mailto:[email protected]]
> Sent: Wednesday, November 23, 2011 12:08 PM
> To: [email protected]
> Subject: Re: Writing long strings PV in BOY
> Juan,
> The only widgets that deal directly with waveform of chars as a long
> string are the text entry/update.  The reason that your code is not
> working is that setValue checks type and the type created by
> createIntArray (int[]) is not one of the recognized types.  Integer []
> is supported so if you can create this ( I'm just not that fluent in
> Javascript ) then I think that you can do what you want.
> I have done a test edit of the code and have come up with the following
> patch that will allow passing int[] to the setValue so that your
> original script should work, although I had trouble since you created
> an
> array of 10 elements but had a longer string.  This section of code is
> not mine so I am going to pass this off to others in the group to
> accept
> & commit.  This will not fix your immediate issue but should make it
> possible to do this in the future.
> John Hammonds
> diff -r a6e2537a9c5c
> core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/pv/
> epics/EPICS_V3_PV.java
> a/core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/p
> v/epics/EPICS_V3_PV.java
> Thu Oct 27 13:54:01 2011 -0500
> b/core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/p
> Wed Nov 23 10:58:49 2011 -0600
> @@ -495,7 +495,7 @@
>                   final int val = ((Integer)new_value).intValue();
>                   channel_ref.getChannel().put(val);
> -            else if (new_value instanceof Integer [])
> +            else if (new_value instanceof Integer [] )
>                   final Integer ival[] = (Integer [])new_value;
>                   final int val[] = new int[ival.length];
> @@ -503,8 +503,12 @@
>                       val[i] = ival[i].intValue();
> +            else if (new_value instanceof int[])
> +                channel_ref.getChannel().put((int[])new_value);
>               } else {
> -                throw new Exception("Cannot handle type "
> +                throw new Exception("Cannot handle data type "
>                                       + new_value.getClass().getName());
> On 11/23/2011 7:27 AM, [email protected] wrote:
> > Hi,
> > I have a waveform record setup as array of char (to support long
> string) and I'm trying to write a string to it via BOY Action button. I
> setup a "Write PV" action in the widget but the string does not get
> written, so perhaps long strings are not supported in BOY actions (it
> works for Text Inputs).
> > I tried a Javascript code to convert the string to an array of char
> via the following code:
> > importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
> > var strArray = DataUtil.createIntArray(10);
> > var pv = widget.getPV();
> > var strText = "this is a test";
> > for(var i=0; i<strText.length; i++) {
> >    strArray[i] = strText.charCodeAt(i);
> > but the script throws an exception in BOY's console "Wrapped
> java.lang.Exception: Cannot handle type [I".
> > Is there any way in BOY to write a string to a waveform record as an
> array of char (support long strings)? I'm using SNS CSS 3.0.2 (Basic)
> for MacOSX.
> > Thanks in advance,
> >    Juan.
> > Juan Carlos Guzman
> > Software Engineer
> > Australia Telescope National Facility
> > CSIRO Astronomy and Space Science
> > P.O.Box 76, Epping NSW 1710, Australia
> > Phone: +61 2 9372 4457
> > Fax: +61 2 9372 4310
> > Email: [email protected]<mailto:[email protected]>
> John Hammonds
> Software Services Group
> APS Engineering Support Division
> Argonne National Laboratory
> (630)252-5317
Re: Writing long strings PV in BOY John Hammonds
Writing long strings PV in BOY Juan.Guzman
Prev: Re: Gateway binary distribution available for RedHat 5.5 Martin Konrad
Next: Re: Writing long strings PV in BOY John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Writing long strings PV in BOY John Hammonds
