Yeah, what about these slashes? )) I've no idea why they are forward. How can it be fixed I wonder?
2011/12/5 Geoff Savage <[email protected]>
How about the the slashes should be back slashes?
On 12/5/2011 10:43 AM, Pavel Masloff wrote:
Geoff!
Wait a minute. I successfully compiled using VS 2010 Express. But
softIoc.exe doesn't want to work:
/filename="..\dbLexRoutines.c" line number=243
Invalid argument dbRead opening file
'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd/
Do you know why this happens?
Let me tell you how I built it.
1. Set global environment variables (EPICS_HOST_ARCH=win32-x86;
PATH=C:\GnuWin32\bin;d:\baseR3.14.12.1\new\bin\win32-x86)
2. Source files are located in d:\baseR3.14.12.1\base-3.14.12.1\
3. INSTALL_LOCATION=d:\baseR3.14.12.1\new
The compilation was successful. There were a few warnings, though.
Pavel
2011/12/5 Geoff Savage <[email protected] <mailto:[email protected]>>
Check everything. Sometimes you have to start again from scratch.
For example, are you positive you are using the compilers from the
mingw installation? All I see in the output is g++. This might
explain why -fpermissive did not work.
Geoff
On 12/5/2011 10:16 AM, Pavel Masloff wrote:
it had been set so prior
2011/12/5 Janet Anderson <[email protected]
<mailto:[email protected]> <mailto:[email protected]
<mailto:[email protected]>>>
__
Looks like the definitions of CC and CCC are incorrect. Try
setting CC=gcc and CCC=g++ in
configure/os/CONFIG_SITE.__win32-x86-mingw.win32-x86-__mingw.
Janet
Hey Mark,
I don't know where this error comes from (the single
quotes). I
thought running softIoc.exe is a simple way to check the
installation.
No, your suggestions didn't work (sorry, partly in
Russian, I can
translate if you need):
"Installing generic include file ../../../include/tsDefs.h"
windres -I. -I../O.Common -I.
-I../../../src/libCom/osi/os/__WIN32
-I../../../src/libCom/osi/os/__posix
-I../../../src/libCom/osi/os/__default -I..
-I../../../src/libCom/__bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd
-I../../../src/libCom/__cxxTemplates
-I../../../src/libCom/dbmf -I../../../
src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/error -I../../../src/libCom/fdmgr
-I../../../src/libCom/freeList -I../../../src/libCom/gpHash
-I../../../src/libCom/iocsh
-I../../../src/libCom/__logClient
-I../../../src/libCom/macLib -I../../../src/libCom/misc
-I../../../src/libCom/osi -I../../../src/libCom/taskwd
-I../../../src/libCom/timer -I../../../src/libCom/tsDefs
-I../../../include/os/WIN32 -I../../../include
../Com.rc
Com.coff
g++ -c -D_MINGW -O3 -Wall -fpermissive
-m32 -D_DLL -MMD -I. -I../O.Common -I.
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/gpHash -I..
/../../src/libCom/iocsh -I../../../src/libCom/__logClient
-I../../
-I../../../inclu
../../../src/libCom/bucketLib/__bucketLib.c
../../../src/libCom/bucketLib/__bucketLib.c: В функции
<ITEM**
bucketStringCompare(ITEM**, const void*)>:
../../../src/libCom/bucketLib/__bucketLib.c:125:21:
предупреждение:
некорректное преобразование из <const void*> в <const
char*> [-fpermissive]
<BUCKETID
bucketUnsignedHash(BUCKET*, const void*)>:
../../../src/libCom/bucketLib/__bucketLib.c:147:25:
предупреждение:
unsigned int*> [-fpermissive]
<BUCKETID
bucketStringHash(BUCKET*, const void*)>:
../../../src/libCom/bucketLib/__bucketLib.c:197:21:
предупреждение:
-m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src
/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/__posix
-I../../../src/libCom/cvtFast -I../../../src/libCom/cppS
td -I../../../src/libCom/__cxxTemplates
-I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../
-I../../../inclu
../../../src/libCom/ring/__epicsRingPointer.cpp
-I../../
-I../../../inclu
../../../src/libCom/ring/__epicsRingBytes.c
../../../src/libCom/ring/__epicsRingBytes.c: В функции
<void*
epicsRingBytesCreate(int)>:
../../../src/libCom/ring/__epicsRingBytes.c:42:78:
предупреждение:
некорректное преобразование из <void*> в <ringPvt* {aka
ringPvt*}> [-fpermissive]
../../../src/libCom/ring/__epicsRingBytes.c:44:63:
предупреждение:
некорректное преобразование из <void*> в <volatile char
*> [-fpermissive]
-I../../
-I../../../inclu
../../../src/libCom/calc/__postfix.c
../../../src/libCom/calc/__postfix.c:129:1: предупреждение:
deprecated conversion from string constant to <char*>
[-Wwrite
-strings]
../../../src/libCom/calc/__postfix.c:163:1: предупреждение:
[-Wwrite
-strings]
../../../src/libCom/calc/__postfix.c: В функции <long int
postfix(const char*, char*, short int*)>:
../../../src/libCom/calc/__postfix.c:272:42: предупреждение:
некорректное преобразование из <int> в <rpn_opcode>
[-fpermis
sive]
-I../../
-I../../../inclu
../../../src/libCom/calc/__calcPerform.c
-I../../
-I../../../inclu
../../../src/libCom/cvtFast/__cvtFast.c
-I../../
-I../../../inclu
../../../src/libCom/__cxxTemplates/resourceLib.cpp
-I../../
../../../src/libCom/__cxxTemplates/epicsOnce.cpp
In file included from
../../../src/libCom/__cxxTemplates/epicsOnce.cpp:29:__0:
../../../src/libCom/__cxxTemplates/epicsSingleton.h:__37:5: ошибка:
<size_t> не является именем типа
../../../src/libCom/__cxxTemplates/epicsSingleton.h: In
constructor
<SingletonUntyped::__SingletonUntyped()>:
../../../src/libCom/__cxxTemplates/epicsSingleton.h:__162:23: ошибка:
в классе <SingletonUntyped> не имеет поля с именем
<_refCount>
mingw32-make[3]: *** [epicsOnce.o] Error 1
mingw32-make[3]: Leaving directory
`C:/epics/base/bin/win32-x86-__mingw/src/libCom/O.win32-x86-__mingw'
mingw32-make[2]: *** [install.win32-x86-mingw] Error 2
mingw32-make[2]: Leaving directory
`C:/epics/base/bin/win32-x86-__mingw/src/libCom'
mingw32-make[1]: *** [libCom.install] Error 2
mingw32-make[1]: Leaving directory
`C:/epics/base/bin/win32-x86-__mingw/src'
mingw32-make: *** [src.install] Error 2
mingw32-make: Leaving directory
`C:/epics/base/bin/win32-x86-__mingw'
On Sun, Dec 4, 2011 at 11:46 PM, Mark Rivers
<[email protected] <mailto:[email protected].edu>
<mailto:[email protected].__edu
<mailto:[email protected].edu>>> wrote:
I don't know about the problem with softIoc. Where
is it
getting those single quotes?
Did you try my suggestion of -fpermissive when
building with
MinGW? I think it should have at least eliminated
the error
you reported.
__________________________________
[mailto:pavel.masloff@gmail.__com
<mailto:pavel.masloff@gmail.com>
<mailto:pavel.masloff@gmail.__com
<mailto:pavel.masloff@gmail.com>>]
Sent: Sun 12/4/2011 1:48 PM
To: Mark Rivers
Cc: [email protected]
<mailto:[email protected]>>__;
<mailto:[email protected] <mailto:[email protected]>>
Subject: Re: [help] EPICS build no good
Hey Mark,
The base I am trying to build is 3.14.12.1.
Mingw32-make didn't work. So i tried Microsoft
Visual Studio
2010 Express. The compilation ended successfully
with a few
warnings.
However, when I try to run softIoc.exe, I see the
following error:
d:\>softIoc
'D:\baseR3.14.12.1\new'/dbd/__softIoc.dbd
Pavel
On Sat, Dec 3, 2011 at 1:26 AM, Mark Rivers
wrote:
Hi Pavel,
What version of base is this?
I think you can avoid this error by adding
this line to
base/configure/os/CONFIG_SITE.__win32-x86-mingw.win32-x86-__mingw
USR_CFLAGS += -fpermissive
USR_CXXFLAGS += -fpermissive
But if this is the latest version of base
then I think
there is an error that should be fixed.
__________________________________________
Sent: Friday, December 02, 2011 4:13 PM
To: Mark Rivers
<mailto:[email protected]>>__; [email protected]
Mark,
I did what you'd proposed.
This is what i get:
-I../../../src/libCom/osi/os/__posix -I../../../src/libC
m/osi/os/default -I..
rc/libCom/cvtFast -I../../../src/libCom/cppStd
-I../../..
-I../../../src/libC
-I../../../src/libC
-I../../../include ../Com.rc Com.coff
-m32
-I../../.
/src/libCom/cxxTemplates
-I../../../s
-I../../../src/l
I../../../include
In function
<ITEM** bucketStringCompare(ITEM**, const void*)>:
error: incorrect transform from <const void*> to
<const char*>
-fpermissive]
in function
<BUCKETID bucketUnsignedHash(BUCKET*, const void*)>:
<const unsigne
In function
<BUCKETID bucketStringHash(BUCKET*, const void*)>:
<const char*>
-fpermissive]
mingw32-make[3]: *** [bucketLib.o] Error 1
On Sat, Dec 3, 2011 at 12:45 AM, Mark Rivers
wrote:
Hi Pavel,
I understand now. I thought you were just
using MinGW
for gnumake. But you want to use the gcc compiler
as well.
You have set the wrong value for
EPICS_HOST_ARCH. You
have set it to win32-x86, which is the architecture that
requires Visual Studio.
You need to set the environment variable
EPICS_HOST_ARCH to win32-x86-mingw. That will use gcc.
Sent: Friday, December 02, 2011 3:41 PM
To: Mark Rivers; [email protected]
Hi Mark,
Do I really need MS Visual Studio?
According to this
(http://www.aps.anl.gov/epics/__base/win32.phphttp://www.aps.__anl.gov/epics/base/win32.php <http://www.aps.anl.gov/epics/base/win32.phphttp://www.aps.anl.gov/epics/base/win32.php>):
Download and install a compiler:
* Microsoft Visual C++ Express 2010, or
* MinGW version of GCC
* You can also use Microsoft's commercial C++
development tools if you have them.
I used MinGW. I see 'or' here.
On Sat, Dec 3, 2011 at 12:27 AM, Mark Rivers
wrote:
Hi Pavel,
I think the problem is that you have not set
up your
environment for Visual Studio. Your PATH
does not include the path to the Visual Studio
compiler. You
need to execute the "vcvarsall.bat file that comes
with Visual
Studio.
This is the batch file I use to set up EPICS
builds for
win32-x86.
rem This file sets up for an EPICS win32-x86
build
set EPICS_HOST_ARCH=win32-x86
rem This is the location of "make"
set PATH=C:\Program
Files\GnuWin32\bin;C:\Perl\__bin;H:\epics\base\bin\win32-__x86;%PATH%
"C:\Program Files\Microsoft Visual Studio
9.0\VC\vcvarsall.bat" x86
<mailto:tech-talk-bounces@aps.anl.gov>
<mailto:tech-talk-bounces@aps.__anl.gov
<mailto:tech-talk-bounces@aps.anl.gov>>
[mailto:tech-talk-bounces@aps.__anl.gov
<mailto:tech-talk-bounces@aps.anl.gov>>] On Behalf Of Pavel
Masloff
Sent: Friday, December 02, 2011 2:52 PM
To: [email protected]
<mailto:[email protected]>>__; Dirk Zimoch;
Subject: [help] EPICS build no good
Hello,
This is my first attempt ever to build EPICS
(and it's
the first time I try to compile something really
big, as a
matter of fact).
In accordance with the following instructions
<http://www.aps.anl.gov/epics/base/win32.php>) and
recommendations by Dirk Zimoch (thanks!), I tried to
build
EPICS baseR3.14.12.1 on Windows 7 Starter using:
* ActiveState Perl
(ActivePerl-5.14.2.1402-__MSWin32-x86)
This is what I get :
rc -l 0x409 -I. -I../O.Common -I.
-I../../../src/libCom/osi/os/__default -I.. -I../../.
./src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../sr
c/libCom/cppStd
-I../../../sr
c/libCom/env -I../../../src/libCom/error
m/gpHash -I../../../src/libCom/iocsh
misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -I.
-fo
Com.res ../Com.rc
process_begin: CreateProcess(NULL, rc -l
0x409 -I.
-I../O.Common -I. -I../../../src/libCom/osi/os/__WIN32
-I../../../src/l
ibCom/osi/os/default -I..
-I../..
-I../../../src/l
-I../../../src/l
-I../../../include/os/WIN32 -I../../../include -fo
Com.res
../Com.rc, ...) failed.
make (e=2): No such file.
mingw32-make[3]: *** [Com.res] Error 2
`C:/epics/base/bin/win32-x86/__src/libCom/O.win32-x86'
mingw32-make[2]: *** [install.win32-x86] Error 2
`C:/epics/base/bin/win32-x86/__src/libCom'
`C:/epics/base/bin/win32-x86/__src'
`C:/epics/base/bin/win32-x86'
Why can it be so? The same thing using GnuWin32:
-I../../../sr
c/libCom/cppStd
-I../../../sr
-fo
Com.res ../Com.rc
0x409 -I.
-I../../../src/l
-I../..
-I../../../src/l
-I../../../src/l
Com.res
I set the PATH Environment Variable to:
C:\Perl\site\bin;C:\Perl\bin;%__SystemRoot%\system32;%__SystemRoot%;%SystemRoot%\__System32\Wbem;%SYSTEMROOT%\__System32\WindowsPowerShell\v1.__0\;C:\Program
Files\WIDCOMM\Bluetooth Software\;C:\Program
Files\QuickTime\QTSystem\;C:\__MinGW\bin;C:\GnuWin32\bin
I don't know if there was a need to do so.
Because I
can see it's mentioned in the win32.bat file. Here's my
win32.bat (in the ming32-make case):
@ECHO OFF
REM
******************************__******************************__*************
REM Copyright (c) 2002 The University of
Chicago, as
Operator of Argonne
REM National Laboratory.
REM Copyright (c) 2002 The Regents of the
University
of California, as
REM Operator of Los Alamos National
Laboratory.
REM EPICS BASE Versions 3.13.7
REM and higher are distributed subject to a
Software
License Agreement found
REM in file LICENSE that is included with this
distribution.
REM
REM Revision-Id:
[email protected]__20110419162804-__n948b5t79d7ctygo
<mailto:[email protected]__20110419162804-__n948b5t79d7ctygo
<mailto:[email protected]20110419162804-n948b5t79d7ctygo>>
REM
REM Site-specific EPICS environment settings
REM
REM sites should modify these definitions
REM
==============================__========================
REM ====== REQUIRED ENVIRONMENT VARIABLES
FOLLOW ======
REM
REM
REM ---------------- WINDOWS
REM
REM ----- WIN95 -----
REM set PATH=C:\WINDOWS;C:\WINDOWS\__COMMAND
REM ----- WINNT, WIN2000 -----
REM set PATH=C:\WINNT;C:\WINNT\__SYSTEM32
REM ----- WINXP, Vista, Windows 7 -----
set
PATH=C:\WINDOWS\system32;C:\__WINDOWS;C:\WINDOWS\SYSTEM32\__Wbem
REM
REM ---------------- make and perl
REM
REM --------------- ActiveState perl
set PATH=C:\Perl\bin;%PATH%
REM --------------- mingw make
set PATH=C:\mingw\bin;%PATH%
REM set PATH=C:\mingw-make82-3\bin;%__PATH%
REM --------------- gnuwin32 make
REM set PATH=C:\gnuwin32\bin;%PATH%
REM
REM ---------------- cygwin tools
REM
REM (make & perl if above perl and make
are REMs)
REM Dont use cygwin GNU make and Perl!
REM cygwin contains tk/tcl, vim, perl, and
many unix
tools
REM need grep from here NOT from cvs directory
REM set PATH=%PATH%;.;..
REM set PATH=%PATH%;c:\cygwin\bin
REM
REM --------------- Visual c++
REM
REM ------ Microsoft Visual Studio 2005 ------
REM call "C:\Program files\Microsoft Visual
Studio
8\VC\vcvarsall.bat" x86_amd64
REM set PATH=%PATH%;C:\Program Files\Microsoft
SDKs\Windows\v6.0A\bin
REM set INCLUDE=%INCLUDE%;C:\Program
Files\Microsoft
SDKs\Windows\v6.0A\include
REM REM set LIBPATH=%LIBPATH%;C:\Program
Files\Microsoft SDKs\Windows\v6.0A\lib
REM set LIB=%LIB%;C:\Program Files\Microsoft
REM ------ Microsoft Visual Studio 2008 ------
Studio
9.0\VC\bin\vcvars32.bat"
Studio
9.0\VC\vcvarsall.bat" x86_amd64
REM set PATH=C:\Program Files\Microsoft
SDKs\Windows\v7.0\bin;%PATH%
REM set INCLUDE=C:\Program Files\Microsoft
SDKs\Windows\v7.0\include;%__INCLUDE%
REM set LIBPATH=C:\Program Files\Microsoft
SDKs\Windows\v7.0\lib;%__LIBPATH%
REM set LIB=C:\Program Files\Microsoft
SDKs\Windows\v7.0\lib;%LIB%
REM ----- Visual Studion 2010 -----
REM -- windows-x64 ---
Studio
10.0\VC\vcvarsall.bat" x64
REM -- win32-x86 ---
Studio
10.0\VC\vcvarsall.bat" x86
REM
REM --------------- EPICS
------------------------------__--
REM
REM set EPICS_HOST_ARCH=windows-x64
set
PATH=%PATH%;C:\epics\base\bin\__%EPICS_HOST_ARCH%
REM set
PATH=%PATH%;G:\epics\__extensions\bin\%EPICS_HOST___ARCH%
REM
REM ------- OPTIONAL ENVIRONMENT VARIABLES
FOLLOW --------
REM
REM
REM ----------------- remote CVS
REM
REM set CVS_RSH=c:/cygwin/bin/ssh.exe
REM set
CVSROOT=:ext:[email protected]:/__usr/local/epicsmgr/cvsroot
<mailto:CVSROOT
<mailto:CVSROOT>=:ext:jba@aps.__anl.gov:/usr/local/epicsmgr/__cvsroot>
REM set HOME=c:/users/%USERNAME%
REM set HOME=c:/users/jba
REM
REM ------------------- Bazaar
REM
REM set PATH=%PATH%;C:\Program files\Bazaar
REM
REM ----------------- GNU make flags
REM
set MAKEFLAGS=-w
REM
REM -------------- vim (use cygwin vim )
REM
REM HOME needed by vim to write .viminfo file.
REM VIM needed by vim to find _vimrc file.
REM set VIM=c:\cygwin
REM
REM --------------- Epics Channel Access
REM Modify and uncomment the following lines
REM to override the
base/configure/CONFIG_ENV defaults
REM
REM set EPICS_CA_ADDR_LIST=n.n.n.n n.n.n.n
REM set EPICS_CA_AUTO_ADDR_LIST=YES
REM set EPICS_CA_CONN_TMO=30.0
REM set EPICS_CA_BEACON_PERIOD=15.0
REM set EPICS_CA_REPEATER_PORT=5065
REM set EPICS_CA_SERVER_PORT=5064
REM set EPICS_TS_MIN_WEST=420
REM
REM --------------- JAVA
------------------------------__---
REM
REM Needed for java extensions
REM set CLASSPATH=G:\epics\extensions\__javalib
REM set PATH=%PATH%;C:\j2sdk1.4.1_01\__bin
REM set
CLASSPATH=%CLASSPATH%;C:\__j2sdk1.4.1_01\lib\tools.jar
REM
REM --------------- Exceed
REM Needed for X11 extensions
REM
REM set EX_VER=7.10
REM set EX_VER=12.00
REM set EX_VER=14.00
REM set PATH=%PATH%;C:\Exceed%EX_VER%\__XDK\
Files\Hummingbird\__Connectivity\%EX_VER%\Exceed\
Didn't change anything else. I think I missed
something. What do you think I've missed?
Thank you.
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
-- Sincerely,
Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
- [help] EPICS build no good Pavel Masloff
- RE: [help] EPICS build no good Mark Rivers
- Re: [help] EPICS build no good Pavel Masloff
- Re: [help] EPICS build no good Geoff Savage
Re: [help] EPICS build no good Andrew Johnson
<2011>
2025
2026
<2011>
2025
2026
