1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: About the interface LabCA problem that Matlab can't read image datafrom areaDetector
Date: Mon, 12 Dec 2011 09:32:59 -0600
On 12/11/2011 04:14 PM, Mark Rivers wrote:
I have not used LabCA but from reading the documentation I think it uses the native data type for Channel Access and then it converts to double in Matlab.
That's indeed the default. However, you can let it use any type for the CA transfer; RTM.
- Till
There are 2 things I can think of.  First make sure that EPICS_CA_MAX_ARRAY_BYTES is set to a value a little larger than the maximum array size on both the IOC server machine and the Matlab client machine.
If that does not fix it then you may need to increase the LabCA timeout
-----Original Message-----
Sent: Sat 12/10/2011 6:14 AM
To: [email protected]
Subject: About the interface LabCA problem that Matlab can't read image datafrom  areaDetector
Hi everbody
    I used procilica camera to read image data in EPICS. And use LabCA as interface to link Matlab and areaDetector based in EPICS. So I met this problem. Maybe the Channel Access interface only supports reading arrays as doubles (64-bit floating points), but the Prosilica is normally sending 8-bit data. Thus when I use Matlab to read image datas, Matlab would shut up automatically. Or that is the other question? Does anyone met this question? And how to solve it ?
     Thank you !
        Peng
About the interface LabCA problem that Matlab can't read image data from areaDetector
RE: About the interface LabCA problem that Matlab can't read image datafrom areaDetector Mark Rivers
Prev: pyepics3 Stripchart howto wanted Peter Milne
Next: Re: Tektronix 3000/5000 oscilloscopes Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: About the interface LabCA problem that Matlab can't read image datafrom areaDetector Mark Rivers
Next: Re: About the interface LabCA problem that Matlab can't read image data from areaDetector Till Straumann
