Andrew,
Thanks for advice - I won't use this plugin =] At least I have learned some Eclipse basics.
Do you know - I have read somewhere - that it is likely to combine EPICS IDE and CSS in the future in one application. Because it would be useful for people who are not very much into creating applications from the command line. Sort of "all in one" control system.
Thanks, Pavel
On Tue, Dec 20, 2011 at 2:22 AM, Andrew Johnson <[email protected]> wrote:
Hi Pavel,
On 2011-12-19 Pavel Masloff wrote:
> Can one install the EPICS IDE plugin *locally*? I mean, download the *.jars
> and install the same way as installing CDT?
> There is only one method proposed - through the Eclipse Update Manager
> using http://www.aps.anl.gov/epics/eclipse/updates as a source.
> If so, where can I download the packet?
The EPICS IDE Plugin is probably not worth installing, I don't know of anybody
who actually uses it. It was written several years by an developer who has
since retired, and as far as I know nobody else has ever looked at his code,
certainly nobody is maintaining it now. It is mostly just a GUI wrapper for
the makeBaseApp.pl script that comes with EPICS Base, and not a comprehensive
one at that.
Don't waste your time on it.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
-- Sincerely,
Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
- question about the promptgroup meaning in DBD file Abadie Lana
- Re: [Eclipse] EPICS IDE plugin Andrew Johnson
- [Eclipse] EPICS IDE plugin Pavel Masloff
Re: [Eclipse] EPICS IDE plugin Pavel Masloff
Employment Opportunities at Varian Medical Systems Doug Murray
<2011>
2025
2026
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
