Hi Andrew
Thanks for the explanation. We will go through the main record types and try to suggest some improvments (but hopefully for next year).
cheers
Lana
Sent: Tuesday, December 20, 2011 9:33 PM
To: [email protected]
Cc: Abadie Lana
Subject: Re: question about the promptgroup meaning in DBD file
Hi Lana,
On 2011-12-20 Abadie Lana wrote:
> Thanks for clarification, the reason is wanted to group the different
> fields: the promptgroup was a good start but sometimes quite hard to
> follow. Lana
VDCT's inspector window can group fields together using the PromptGroup
information, but most of the standard record types were developed by a number
of different people and not all of the authors understood how that worked.
If someone could go through all the record types and clean up these values to
group the fields more sensibly I would be very happy to merge the resulting
changes into Base.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- [Eclipse] EPICS IDE plugin Pavel Masloff
- Re: [Eclipse] EPICS IDE plugin Pavel Masloff
- question about the promptgroup meaning in DBD file Abadie Lana
- Re: question about the promptgroup meaning in DBD file Andrew Johnson
Re: CA Watcher - an other camonitor Pavel Masloff
Re: [make] mingw, gnuwin32, cygwin Pavel Masloff
<2011>
2025
2026
Re: [Eclipse] EPICS IDE plugin Andrew Johnson
<2011>
2025
2026
