1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: linux-gpib with asyn
To: [email protected]
Date: Wed, 11 Jan 2012 16:40:39 +0100
Hi Stuart,
we have recently set up a small linux box with ines_pci_gp5130 board.
See the small snipped from st.cmd how we call GpibBoardDriverConfig
#  GpibBoardDriverConfig(portName,autoConnect,BoardIndex,timeout,priority)
GpibBoardDriverConfig("L1",1, 0, 3.0, 0)
and content of file gpib.conf of that box:
more /etc/gpib.conf
                 GPIB.CONF IEEE488 library config file
   copyright            : (C) 2002 by Frank Mori Hess
                          (C) 1994 by C.Schroeter
   email                : [email protected]
 *   Syntax:
 *         interface { ... } starts new interface board section
 *         device {...} device configuration
interface {
        minor = 0
        board_type = "ines_pci_gp5130"
        name = "L1"
        pad = 0
        sad = 0
        eos = 0x0a      /* EOS Byte, 0xa is newline and 0xd is carriage
return */
        set-reos = yes  /* Terminate read if EOS */
        set-bin = no    /* Compare EOS 8-bit */
        set-xeos = no   /* Assert EOI whenever EOS byte is sent */
        set-eot = yes   /* Assert EOI with last byte on writes */
        master = yes
We have connected instruments of different vendors to the bus: Keithley,
HP, Datron and we also get replies where the first character is NULL. We
never saw this on an E5810 LAN-GPIB gateway, thus it must be due to the
board or linux-gpib driver.
Currently we are using epics 3.14.12.1 and asyn 4-16
What sw releases and kind of board are you using?
Regards
Peter
Am 09.01.2012 14:28, schrieb Wilkins, Stuart:
> Hi!
> I have been using linux-gpib and asyn (and StreamDevice) for
> communication with Keithley Electrometers. I have one comment on the
> documentation and one bug which I would like to see if anyone else has seen.
> Firstly, according to the asyn documentation the following command at
> the iocsh sets up the board.
>  From this documentation, it looks like you assign the GPIB board with
> the integer "board index", however after about 2 hrs of trying to get
> this working, I delved into the souce code for this driver. In fact,
> this is not the behavior in the code, the port driver tries to open the
> gpib card with the same name as the portName as defined in
> /etc/gpib.conf. I think (although in places the code is fairly cryptic)
> it is only if you open a certain gpib address that it uses board index,
> but I cannot find the config to give the primary and secondary address
> at the iocsh. It might be a good idea to update this in the asyn
> documentation (or at least clarify it!)
> Having got past this stage, I noticed that some of my communications are
> being garbled, with replies returning where the first character is NULL
> [chr$(0)] instead of the correct character. Has anyone seen this
> behavior. I am not sure if it is due to the linux-gpib driver, asyn or
> the Keithley. I plan to put another device on the bus to see if it is
> just this combination. Is anyone out there using this combination?
> Best wishes,
> Stuart
phone:        +49 30 3481 7111
fax:        +49 30 69 3481 7111
eMail:        [email protected]
Postalische Anschrift / mailing address:        |        Besucheranschrift / Visitors address:
Peter Müller        |
in        |
Physikalisch-Technische Bundesanstalt        |        Helmholtzzentrum für Materialien und Energie
O.E. 7.11 Röntgenradiometrie        |        Wilhelm-Conrad-Röntgen Campus
Abbestraße 2-12        |        Albert-Einstein-Straße 15
D-10587 Berlin        |        12489 Berlin
Prev: RE: pyepics: Strategies for working with fast-changing large arrays Mark Rivers
Next: porting strategy from IDL Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: linux-gpib with asyn Dirk Zimoch
Next: Any CAMAC users left? Paul Sichta
