1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS X-Y Graph
To: [email protected]
Date: Tue, 21 Feb 2012 19:36:22 -0500
Andrew,
I don't know if this matters but my waveform is actually one of the outputs of a genSub record. It has a NOVA field but I could alternately use another output as a array length indicator field.
BTW, I am also open to doing this in EDM or MEDM or ???
John Dobbins
On 2/21/2012 7:17 PM, Andrew Johnson wrote:
Hi Michael,
On 2012-02-21 Michael Davidsaver wrote:
I too have had trouble doing this.  I was able to setup a rule to set
the buffer size from the NORD field of a waveform record.  The result
was that, when the size was reduced, the start of the waveform was
removed instead of the end.  So not very useful.
Also note that the NORD field of a waveform record does not get monitors
posted on it unless there is device support that explicitly does that, so this
wouldn't necessarily work too well anyway (you could forward-link the waveform
record to a longin that reads the NORD field and use that instead though).
In 3.15 any device support will still be responsible for posting monitors if
it sets NORD, but the record and soft device support will also do it when they
set NORD.
- Andrew
Re: CSS X-Y Graph Eric Norum
CSS X-Y Graph John Dobbins
Re: CSS X-Y Graph Michael Davidsaver
Re: CSS X-Y Graph Andrew Johnson
Prev: Re: CSS X-Y Graph Andrew Johnson
Next: Re: CSS X-Y Graph Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
