MEDM supports variable-length waveform plots -- set the "Count Num or Channel" to the PV holding the number of points. I usually work around the no-monitors-on-NORD problem by forward linking my waveform records to a longin record that gets its value from the waveform NORD field -- I then set the MEDM "Count Num or Channel" to that longin record -- which does post monitors on changes. This latter problem will be moot on arrival of 3.15, of course.
On Feb 21, 2012, at 4:36 PM, John Dobbins wrote:
> Andrew,
> I don't know if this matters but my waveform is actually one of the outputs of a genSub record. It has a NOVA field but I could alternately use another output as a array length indicator field.
> BTW, I am also open to doing this in EDM or MEDM or ???
> John Dobbins
> On 2/21/2012 7:17 PM, Andrew Johnson wrote:
>> Hi Michael,
>> On 2012-02-21 Michael Davidsaver wrote:
>>> I too have had trouble doing this. I was able to setup a rule to set
>>> the buffer size from the NORD field of a waveform record. The result
>>> was that, when the size was reduced, the start of the waveform was
>>> removed instead of the end. So not very useful.
>> Also note that the NORD field of a waveform record does not get monitors
>> posted on it unless there is device support that explicitly does that, so this
>> wouldn't necessarily work too well anyway (you could forward-link the waveform
>> record to a longin that reads the NORD field and use that instead though).
>> In 3.15 any device support will still be responsible for posting monitors if
>> it sets NORD, but the record and soft device support will also do it when they
>> set NORD.
>> - Andrew
Eric Norum
[email protected]
- Re: CSS X-Y Graph John Dobbins
- CSS X-Y Graph John Dobbins
- Re: CSS X-Y Graph Michael Davidsaver
- Re: CSS X-Y Graph Andrew Johnson
RE: QT-based tools: Expressions of interest requested Andrew Rhyder
<2012>
2025
2026
<2012>
2025
2026
