1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Announce: sequencer release 2.1.5
To: <[email protected]>
Date: Wed, 29 Feb 2012 20:27:25 +0100
Hi All
This is a bug fix release for the stable version 2.1 branch.
As usual, documentation, release notes, download links, and install
instructions can be found on the sequencer homepage:
  http://tinyurl.com/epics-seq/
User relevant changes since 2.1.4 are:
* fixed two bugs in pvAssign:
  - after an initially unassigned variable gets assigned using
    pvAssign in safe mode, pvGet crashed the program
  - when pvAssign was used to re-assign an already connected PV,
    this was not correctly accounted for and a wrong warning
    message was issued
* extended the 'reassign' test to cover these issues
* functions pvAssign and seq_connect (internal) leaked memory
  when something fails; this has been fixed
* several documentation fixes (thanks to Lewis Muir)
* fixed a build problem with older base releases
  (thanks to Bruce Hill)
* internal renamings: SEQ_VERSION->SEQ_RELEASE, seqVersion->seq_release
* know problems of published releases will from now on be
  listed on an extra documentation page, with a link from the
  release notes
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführerin: Prof. Dr. Anke Rita Kaysser-Pyzalla
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Announce: sequencer release 2.1.5 Benjamin Franksen
Prev: Re: Operator display description Andrew Johnson
Next: Re: QT-based tools: Expressions of interest requested Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Announce: sequencer release 2.1.5 Benjamin Franksen
