1/ qt designer demo 2/ qt designer demo with epics aware widget 3/ look at the xml (ui) code generated 4/ start from the shell of a application that takes the xml file as an arg and display its content and connect to PV and change values of PV (ASgui like) 5/ open multiple displays and characterize the load on the machine After seeing the above, I can immediately ditch m/edm 6/ look at installation procedure 7/ look at migration tools (m/edm to Qt) 8/ look at code of a simple interface to Qt (without using designer in C++ / python) 9/ integration with windows, linux, mac osx GUI themes complete control system environment 10/ traditional applications (Striptool, adt, feedback app, alarm handler...) ported to Qt 11/ 3rd party app (video viewers, ..., non epics aware) <-- I believe the GigE pyqt app from Pavel is in that category I believe as a group, today we can do 1 through 9. Heck, if we are lucky one single computer guru from Australia can do 1 through 9 alone ;-) -- E
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
