1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Epics gateway writeNotify issue
To: <[email protected]>
Date: Thu, 1 Mar 2012 10:09:22 +0100
Hello everybody,
I recompiled the epics gateway with the base.3.14.12. Now if I try to execute a writeNotify I always get the following error in the log file:
Virtual gateVcData::write called for <channel name>
   This is an error!
I searched for the source of this error and I found it in the file gateVc.cc (gateway/):
// This is the virtual write function defined in casPV.  It should no
// longer be called if casChannel::write is implemented.
caStatus gateVcData::write(const casCtx& ctx, const gdd& dd)
        fprintf(stderr,"Virtual gateVcData::write called for %s.\n"
          "  This is an error!\n",name());
        return S_casApp_noSupport;
This function is actually called by this piece of code in casPV.cc (which is in
epics base/):
// casPV::writeNotify()
caStatus casPV :: writeNotify (
    const casCtx & ctx, const gdd & val )
    // plumbed this way to preserve backwards
    // compatibility with the old interface which
    // did not include a writeNotify interface
        return this->write ( ctx, val );
With the epics base.3.14.8 there was no problem.
Has anyone idea how to solve this problem?
Thank you for your help,
Cheers,
Matteo
RE: Epics gateway writeNotify issue Hill, Jeffrey O
Prev: Re: QT-based tools: Expressions of interest requested Emmanuel Mayssat
Next: Re: Announce: sequencer release 2.1.5 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Announce: sequencer release 2.1.5 Benjamin Franksen
Next: RE: Epics gateway writeNotify issue Hill, Jeffrey O
