1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: TDS 3000 on win32-x86
To: Pavel Masloff <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 5 Mar 2012 15:06:49 +0000
You do need to include the port number in the drvAsynIPPortConfigure command.  I don't think port 80 is what you want to use, but I don't know enough about these devices to know what port you do want to use.
From: [email protected] [[email protected]] on behalf of Pavel Masloff [[email protected]]
Sent: Monday, March 05, 2012 8:58 AM
To: EPICS Tech Talk
Subject: TDS 3000 on win32-x86
Mark,
Thanks for such a quick response! Yeah, I forgot to include that dbd. I have recompiled and here what I've got:
drvAsynIPPortConfigure("L0", "172.20.92.3", 0, 0, 0)
drvAsynIPPortConfigure: "172.20.92.3" is not of the form "<host>:<port> [protocol]"
Port L0 connectDevice failed: asynManager:connectDevice port L0 not found
asynOctetSetOutputEos("L0",0,"\n")
Which port should I use: 172.20.92.3:80<http://172.20.92.3:80>? The 80th? I don't know actually, but in the Tektronix's prefs (Instrument Setup) I see the option Http Port: 80. Though, I don't know this is the correct port. I presume, it's just for the simple http access via the internet browser. I'm stuck. Please, help!
PAvel
On Mon, Mar 5, 2012 at 6:38 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Pavel,
This error
ERROR: vxi11Configure is not supported on WIN32
is expected because there is no support for VXI-11 on win32-x86, because we don't have an implementation of Sun RPC for win32-x86, which the VXI-11 support requires.
However, this error:
st.cmd -- Line 50 -- Command drvAsynIPPortConfigure not found.
is not expected.  The drvAsynIPPortConfigure command works fine on win32-x86.  You must have a mistake in building your application, perhaps you forgot to include "drvAsynIPPort.dbd" in your dbd file.
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Pavel Masloff [[email protected]<mailto:[email protected]>]
Sent: Monday, March 05, 2012 8:31 AM
To: EPICS Tech Talk; Nicholas P. DiMonte
Hi Nick et al. :
I am trying to use your Tektronix TDS-3000 support on win32-x86. And I have found that it neither works via "Direct network connection" nor "GPIB/LAN connection":
Is there a possibility to talk to the TDS 3054C device any other way on win32? If so, could you give me a hint?
If using "Remote serial port", the following errors occur:
asynOctetSetInputEos("L0",0,"\n")
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
TDS 3000 on win32-x86 Pavel Masloff
RE: TDS 3000 on win32-x86 Mark Rivers
Prev: TDS 3000 on win32-x86 Pavel Masloff
Next: IRMIS3 information please Xu, Kanglin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
