On 3/7/12 2:50 AM, Dirk Zimoch wrote:
> Hi Lewis,
> Can it be that you did not do a "make clean" when you changed
> the optimization level?
> I am speculating a bit now:
> These two functions,
> epicsSingleton<localHostName>::reference::~reference(void) and
> epicsSingleton<localHostName>::reference::operator->(void) both
> contain 'assert' (see src/libCom/cxxTemplates/epicsSingleton.h).
> 'assert' is a macro:
> # define assert(exp) ((exp) ? (void)0 : \
> epicsAssert(__FILE__, __LINE__, #exp, epicsAssertAuthor))
> Depending on the optimization level, '(void)0' may be eliminated
> and the code becomes shorter (by 4 bytes = 1 PPC instruction).
> Try to 'make clean' in the epics base top directory and compile
> again.
Hi, Dirk.
Thanks for the suggestion. I'm pretty sure I did a "make
clean", but I tried again just now to be sure, and the problem
still remains. :-(
Lewis
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Andrew Johnson
- "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
Re: References about EPICS Matthias Clausen
motor module R6-7-1 released Ron Sluiter
<2012>
2025
2026
<2012>
2025
2026
