Subject: |
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 7 Mar 2012 11:02:30 -0600 |
Hi Dirk,
> On 3/7/12 2:50 AM, Dirk Zimoch wrote:
> > These two functions,
> > epicsSingleton<localHostName>::reference::~reference(void) and
> > epicsSingleton<localHostName>::reference::operator->(void) both
> > contain 'assert' (see src/libCom/cxxTemplates/epicsSingleton.h).
> > 'assert' is a macro:
> > # define assert(exp) ((exp) ? (void)0 : \
> > epicsAssert(__FILE__, __LINE__, #exp, epicsAssertAuthor))
> > Depending on the optimization level, '(void)0' may be eliminated
> > and the code becomes shorter (by 4 bytes = 1 PPC instruction).
> > Try to 'make clean' in the epics base top directory and compile
> > again.
The problem is more subtle than that, although I suspect that different
optimization levels is probably the underlying cause.
Remember Lewis is using a very old version of g++, from back when C++
templates were new; my guess is that ldppc is recompiling the template
instances it needs to link the code behind the scenes, but it wasn't told the
optimization level that g++ppc used to compile the instances that appear in
the .o files it's linking with so it doesn't get the same length code and
generates that warning. There may be a flag we could turn on to show more
about what's going on inside ldppc, but it's really not worth looking into
IMHO; better to spend the time upgrading to vxWorks 5.5.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
- "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
motor module R6-7-1 released Ron Sluiter
COV service for EPICS BACnet-driver is ready. Webb, Steven B.
<2012>
2025
2026
<2012>
2025
2026
