Subject: Re: undefined symbol: O_CREAT
To: Dirk Zimoch <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 9 Mar 2012 09:54:07 -0500
Hi:
I think you're using that in the vxWorks shell,
in the st.cmd.
As Dirk wrote, O_CREAT is a #define for the C/C++ preprocessor.
It's not available in the vxWorks shell.
In the vxWorks shell you'll have to use the numeric value 0, 1, ...
that you determine from the #include file, something like this:
fgrep -r O_CREAT /usr/include/*
/usr/include/sys/fcntl.h:#define	O_CREAT		0x0200		/* create if nonexistant
-Kay
On 3/9/12 09:22 , "Dirk Zimoch" <[email protected]> wrote:
>ÕÅÓñÁÁ wrote:
>> Hello,
>> I tried to open a file on my linux host machine via vxworks function
>>open("filename", O_CREAT|O_WRONLY, 0644) from target ME5100. When I run
>>the start file st.cmd ,it printed "undefined symbol: O_CREAT". Which
>>supprot should add to the vxworks kernel image?
>> Thank you in advance!
>> Zhang Yuliang
>> Insititute of High Energy Physics
>O_CREAT is a macro that should be defined when you #include <fcntl.h>.
>Didn't you get any compiler warnings? They are often more useful than
>errors from the loader.
>Didn't you have any problems with O_WRONLY? O_CREAT and O_WRONLY are
>defined in the same file!
>Dirk
Re: undefined symbol: O_CREAT Dirk Zimoch
Prev: Re: undefined symbol: O_CREAT Dirk Zimoch
Next: Invitation to test cothread.catools release candidate michael.abbott
Next: Re: undefined symbol: O_CREAT Dirk Zimoch
