Subject: Re: undefined symbol: O_CREAT
To: "Kasemir, Kay" <[email protected]>
Date: Fri, 09 Mar 2012 17:27:48 +0100
Kasemir, Kay schrieb:
Hi:
I think you're using that in the vxWorks shell,
in the st.cmd.
Thanks Kay! I completely missed that point. I thought is was a compiled program that failed to load in the st.cmd.
Zhang Yuliang, sorry for my misleading previous mail.
It is an annoying issue with vxWorks that the shell does not know about macros and often the manuals don't mention the numerical values. The only way is then to look up the values in the vxWorks header files.
Dirk
As Dirk wrote, O_CREAT is a #define for the C/C++ preprocessor.
It's not available in the vxWorks shell.
In the vxWorks shell you'll have to use the numeric value 0, 1, ...
that you determine from the #include file, something like this:
fgrep -r O_CREAT /usr/include/*
/usr/include/sys/fcntl.h:#define	O_CREAT		0x0200		/* create if nonexistant
-Kay
On 3/9/12 09:22 , "Dirk Zimoch" <[email protected]> wrote:
ÕÅÓñÁÁ wrote:
Hello,
I tried to open a file on my linux host machine via vxworks function
open("filename", O_CREAT|O_WRONLY, 0644) from target ME5100. When I run
the start file st.cmd ,it printed "undefined symbol: O_CREAT". Which
supprot should add to the vxworks kernel image?
Thank you in advance!
Zhang Yuliang
Insititute of High Energy Physics
O_CREAT is a macro that should be defined when you #include <fcntl.h>.
Didn't you get any compiler warnings? They are often more useful than
errors from the loader.
Didn't you have any problems with O_WRONLY? O_CREAT and O_WRONLY are
defined in the same file!
Dirk
Re: undefined symbol: O_CREAT Kasemir, Kay
Prev: Invitation to test cothread.catools release candidate michael.abbott
Next: Here is a Message Szalata, Zenon M.
Prev: Re: undefined symbol: O_CREAT Kasemir, Kay
Next: Invitation to test cothread.catools release candidate michael.abbott
