Subject: iocshCmd, redirection, and function pointers
To: EPICS Tech Talk <[email protected]>
Date: Tue, 13 Mar 2012 14:11:52 -0700
Hello,
When using redirection of output to a file in iocshCmd where the command is one that calls report functions via function pointer like dbior:
iocshCmd("dbior > /dat/dbiorOutput")
the output file contains only the output (printf) from the dbior routine itself but not output (printf) from each driver (called using a function pointer in drvet).
Is this a limitation of the iocsh, mixing C and C++, or the non-thread-safeness (as advertised in the app dev guide) of iocshCmd?  Or am I doing something else wrong?  It  happens on linux-x86_64, RTEMS 4.9.4, and vxWorks 5.4.
Thank you,
Stephanie Allison
Here is dbior done at the ioc prompt and one redirected to a testing file.  The testing file doesn't get any detail:
iocrpdev>dbior()
Driver: drvAsyn
gammaspare1 multiDevice:No canBlock:Yes autoConnect:Yes
gammaspare2 multiDevice:No canBlock:Yes autoConnect:Yes
gamma6032 multiDevice:No canBlock:Yes autoConnect:Yes
Driver: drvEtherIP
drvEtherIP V2.23 - ControlLogix 5000 PLC via EtherNet/IP
Driver: s7plc
$Id: drvS7plc.c,v 1.6 2011/09/01 17:27:42 saa Exp $
Driver: stream
  StreamDevice 2.4 built Aug 16 2011 18:19:07
  registered bus interfaces:
    AsynDriverInterface
    DummyInterface
    DebugInterface
Device Support: devGpib
Device Support: s7plcMbbiDirect
devS7mem version: $Id: devS7plc.c,v 1.5 2011/09/23 15:44:05 saa Exp $
iocrpdev>iocshCmd("dbior > $(IOC_DATA)/iocrpdev/testing")
more $IOC_DATA/iocrpdev/testing
Driver: drvAsyn
Driver: drvEtherIP
Driver: s7plc
Driver: stream
Re: iocshCmd, redirection, and function pointers Eric Norum
Prev: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Next: Re: iocshCmd, redirection, and function pointers Eric Norum
Prev: GPIB SRQ with StreamDevice Eric Williams
