Subject: Re: iocshCmd, redirection, and function pointers
To: "Allison, Stephanie" <[email protected]>
Date: Tue, 13 Mar 2012 14:22:46 -0700
For I/O redirection to work a source file must include epicsStdioRedirect.h.
It's likely that lots of support modules and drivers have not yet done so.
On Mar 13, 2012, at 2:11 PM, Allison, Stephanie wrote:
> Hello,
> When using redirection of output to a file in iocshCmd where the command is one that calls report functions via function pointer like dbior:
> iocshCmd("dbior > /dat/dbiorOutput")
> the output file contains only the output (printf) from the dbior routine itself but not output (printf) from each driver (called using a function pointer in drvet).
> Is this a limitation of the iocsh, mixing C and C++, or the non-thread-safeness (as advertised in the app dev guide) of iocshCmd?  Or am I doing something else wrong?  It  happens on linux-x86_64, RTEMS 4.9.4, and vxWorks 5.4.
> Thank you,
> Stephanie Allison
Eric Norum
[email protected]
RE: iocshCmd, redirection, and function pointers Mark Rivers
Re: iocshCmd, redirection, and function pointers Dirk Zimoch
iocshCmd, redirection, and function pointers Allison, Stephanie
Prev: iocshCmd, redirection, and function pointers Allison, Stephanie
Next: Re: SmarAct / SmarPod Ernest L. Williams Jr.
Next: RE: iocshCmd, redirection, and function pointers Mark Rivers
