1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: iocshCmd, redirection, and function pointers
To: "'Eric Norum'" <[email protected]>, "Allison, Stephanie" <[email protected]>
Date: Tue, 13 Mar 2012 22:13:57 +0000
Thanks to Eric for pointing this out, I was not aware of it.
I have just made 2 changes to the asyn module to enable I/O redirection using both the "dbior" and "asynReport" commands.
I tested it with an areaDetector driver and it seems to work fine:
epics> dbior > dbior.out
epics> asynReport > asynReport.out
This is now committed to the Subversion repository, where it can be accessed from the Web, and it will be in the R4-19 release.
The asynTrace command already has a more powerful I/O redirection capability:
asynSetTraceFile portName addr filename
This allows one to redirect the trace (debugging) output at the level of a specific device, i.e. a single motor axis, etc.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Eric Norum
Sent: Tuesday, March 13, 2012 4:23 PM
To: Allison, Stephanie
Cc: EPICS Tech Talk
Subject: Re: iocshCmd, redirection, and function pointers
For I/O redirection to work a source file must include epicsStdioRedirect.h.
It's likely that lots of support modules and drivers have not yet done so.
On Mar 13, 2012, at 2:11 PM, Allison, Stephanie wrote:
> Hello,
> When using redirection of output to a file in iocshCmd where the command is one that calls report functions via function pointer like dbior:
> iocshCmd("dbior > /dat/dbiorOutput")
> the output file contains only the output (printf) from the dbior routine itself but not output (printf) from each driver (called using a function pointer in drvet).
> Is this a limitation of the iocsh, mixing C and C++, or the non-thread-safeness (as advertised in the app dev guide) of iocshCmd?  Or am I doing something else wrong?  It  happens on linux-x86_64, RTEMS 4.9.4, and vxWorks 5.4.
> Thank you,
> Stephanie Allison
Eric Norum
[email protected]
iocshCmd, redirection, and function pointers Allison, Stephanie
Re: iocshCmd, redirection, and function pointers Eric Norum
Prev: Re: SmarAct / SmarPod Ernest L. Williams Jr.
Next: Re: MVME2434-1 Bill Lavender
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: iocshCmd, redirection, and function pointers Eric Norum
Next: Re: iocshCmd, redirection, and function pointers Dirk Zimoch
