1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Tue, 13 Mar 2012 14:30:56 -0500
On 3/13/12 5:07 AM, Dirk Zimoch wrote:
> Andrew, Lewis,
> If the C++ template instantiation is the problem, then the
> -fno-implicit-templates command line option may help. If that is
> used, the compiler will not create any code "behind the scenes".
Hi, Dirk.
That option is being used.
> Instead it requires that for each template, you explicitly
> specify in which file you want to have the implementation. See
> section "Where's the Template?" in the gcc info pages.
> In exactly one source code file one has to write a line like
> template class epicsSingleton<localHostName>::reference;
I added the above line to src/ca/cac.cpp, but now the build
fails.  (See attached log.)  So maybe I need to add it to a
different file (e.g. src/libCom/cxxTemplates/epicsSingleton.h),
or maybe I need to remove things from other files?
Lewis
> Andrew Johnson wrote:
>> Hi Dirk,
>>> On 3/7/12 2:50 AM, Dirk Zimoch wrote:
>>>> These two functions,
>>>> epicsSingleton<localHostName>::reference::~reference(void) and
>>>> epicsSingleton<localHostName>::reference::operator->(void) both
>>>> contain 'assert' (see
>>>> src/libCom/cxxTemplates/epicsSingleton.h).
>>>> 'assert' is a macro:
>>>> #   define assert(exp) ((exp) ? (void)0 : \
>>>>         epicsAssert(__FILE__, __LINE__, #exp,
>>>> epicsAssertAuthor))
>>>> Depending on the optimization level, '(void)0' may be
>>>> eliminated
>>>> and the code becomes shorter (by 4 bytes = 1 PPC instruction).
>>>> Try to 'make clean' in the epics base top directory and compile
>>>> again.
>> The problem is more subtle than that, although I suspect that
>> different optimization levels is probably the underlying cause.
>> Remember Lewis is using a very old version of g++, from back
>> when C++ templates were new; my guess is that ldppc is
>> recompiling the template instances it needs to link the code
>> behind the scenes, but it wasn't told the optimization level
>> that g++ppc used to compile the instances that appear in the
>> .o files it's linking with so it doesn't get the same length
>> code and generates that warning.  There may be a flag we could
>> turn on to show more about what's going on inside ldppc, but
>> it's really not worth looking into IMHO; better to spend the
>> time upgrading to vxWorks 5.5.
>> - Andrew
Attachment: epics-3.14.12.2-build-r3.txt.gz
Description: GNU Zip compressed data
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
"Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Andrew Johnson
Prev: Re: [Operating System platforms] which one do you use? Emmanuel Mayssat
Next: iocshCmd, redirection, and function pointers Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
Next: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
