Hello tech-talkers,
I would like to implement a simple command record, the idea of which is to switch its VAL to 1 and then back to 0. Let's assume we have got the following record:
record (bo,"cmd:valve_trigger")
{ field(PINI, "YES") field(DTYP, "S7plc") field(OUT, "@plc/0 T=UINT8 B=0") field(SCAN, "I/O Intr") field(ONAM, "ONE") field(ZNAM, "ZERO")
Is there any straightforward solution? Thank you.
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
- Re: [db] simple command ? Hartman, Steven M.
- Re: [db] simple command ? Tim Mooney
Re: Inspect Samples of CSS shows inconsistent SEVR Burkhard Kolb
Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
<2012>
2025
2026
DataBrowser "Optimized" data Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
