> I don't manage to write a FLOAT32_LE:
Please be more specific. Do you get an error, or just incorrect data in the Modbus device?
Can you please turn on asynTrace of both the AR-GT7-PC3 and AR-GT7-PC3:Write_IConsFLE port drivers and send the output when your ao record processes.
-----Original Message-----
Sent: Friday, April 06, 2012 9:47 AM
To: Eric Norum
Cc: tech-talk; Mark Rivers
Subject: Re: Proposed support for additional Modbus data types
- I don't understand why the Linux IOC crash is not reproducible ...
so now the behaviour is the same on both Linux and VxWorks:
Data in the waveform are equal to zero if scan is I/O Intr
Data are correct in the waveform if scan is periodic
- I've successfully tested the read INT32_LE function.
here is my record:
record(ao, "$(EQPT):TstICons") {
field(SCAN, "Passive")
field(DTYP, "asynFloat64")
field(OUT, "@asyn($(EQPT):Write_IConsFLE 0)FLOAT32_LE")
here is my drvModbusAsynConfigure:
drvModbusAsynConfigure("AR-GT7-PC3:Write_IConsFLE", "AR-GT7-PC3", 255, 16 , 5 , 2 , 7 , 1 , "InterfaceIocaste")
do you see any incorrect setting ?
Regards
Le 05/04/2012 17:25, Eric Norum a écrit :
> On Apr 5, 2012, at 7:19 AM, haquin wrote:
>> Hi Mark,
>> I started to test the new release R2-4 of your modbus driver,
>> 1/ I have a regression problem:
>> in case of "intarray_in" when scan mode is I/O Intr:
>> Linux IOC crashes with segmentation error message
> Could you run this again under GDB and send a stack trace?
>> VxWorks IOC doesn't crash but data in the waveform are equal to zero
>> On Linux if I start with the scan mode set to none there is no crash.
> What happens if you change the mode to I/O Intr after the IOC has started?
>> In both cases linux and VxWorks,
>> if I change the scanning mode to any periodic scan (with a caput in the SCAN field), I do retreive correct data.
>> drvModbusAsynConfigure("AR-GT7-PC3:Read_All", "AR-GT7-PC3", 255, 4 , 0 , 46 , 0 , 2000 , "InterfaceIocaste")
>> here is my waveform:
>> record(waveform, "$(EQPT):ReceiveModbusTable") {
>> field(DTYP, "asynInt32ArrayIn")
>> field(FLNK, "$(EQPT):TrigModbusTableProcessing")
>> field(INP, "@asyn($(EQPT):Read_All 0)MODBUS_DATA")
>> field(NELM, "46")
>> field(FTVL, "LONG")
>> field(SCAN, "I/O Intr")
>> 2/ I have tested the retreival of float32_LE with ai record, this is ok
>> tomorrow I'll test retreival of int32 and also he writting.
>> best regards.
- Proposed support for additional Modbus data types Mark Rivers
- RE: Proposed support for additional Modbus data types Mark Rivers
- Re: Proposed support for additional Modbus data types haquin
- Re: Proposed support for additional Modbus data types Eric Norum
<2012>
2025
2026
<2012>
2025
2026
